Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-04-2006, 08:36 AM
briand212 briand212 is offline
96 Sunfire GT rough Idle no power and sucking gas
I have a 96 sunfire gt 2.4 5 speed manual.
currently my car is idleing rough, has lost significant power when accelerating, and is going thru gas like mad. no engine light
History
My car started running rough on the way home about two weeks ago.
I noticed the next day the catylitic was glowing red so I figured hey bad cat and replaced it. this did not fix the problem new one is overheating as well.
I went to advance auto parts and they hooked up a scanner but there are no codes set
I have tried cleaning the injectors, changed the spark plugs, cleaned the throttle body and checked all the vaccum hoses, including the map sensor hose.
I have ohmed out the injectors and used a noid light on the harness
I have backed probed every sensor I could but still cant find the problem.
I am not sure how to check the egr or timing ( dont have a scanner)
Any suggestions would be GREATLY appreciated
Old 02-04-2006, 11:10 AM
hotbug1776's Avatar
hotbug1776 hotbug1776 is offline
Re: 96 Sunfire GT rough Idle no power and sucking gas
perhaps you got a bad coil pack, it's tough to check them because of the idi cover, but I believe it's possible.
that would be my next guess.
Old 02-06-2006, 02:50 PM
I checked the coil packs per the manual and they checked out ok.
Old 02-07-2006, 02:16 AM
hotbug1776's Avatar
how many miles, and has the timing chain made any noise? what about a compression check? Did you check and clean the IAC? If you did, did you move the IAC? It could have damaged the servomotor if you did. After all, the IAC controls the Idle mixture, and can affect the off idle mixture as well.
the timing is computer controlled, as is the EGR. IF the chain jumped (should have been preceeded by some noise) a tooth, I dont think it will smack the piston (it might though, as you have a zero clearance motor) but it will make a power issue occur.
A lot of "if's" on this one. it needs more attention though.
Heck for that matter, the balance shafts may have jumped a tooth, you can never tell. Run down the list and keep checking, it's bound to be there.
Old 04-27-2006, 01:31 AM
xtremamu xtremamu is offline
Check plastic coil housing (tower) You will most likely find a burnt spot.. or at least smell a burnt smell. It seems to be a common problem. but dont find much info about it.. The part is not very expensive and easy to change..
Old 04-28-2006, 01:32 PM
ThePrairieProphet ThePrairieProphet is offline
Send a message via MSN to ThePrairieProphet Send a message via Yahoo to ThePrairieProphet
another thought, i had some major issues of a similar nature with my car a few years ago, the 97 2.4. After numerous diagnostics, they sent of an advanced diagnostics to some GM place and it turned out that my EGR valve was staying open just a few percent, which went unnoticed most places, and set off wrong codes in my computer. They replaced the EGR valve and fixed the problem.
What the hell does rant mean?
www.stillseed.com
