Old 02-04-2006, 07:31 AM
altonjh altonjh is offline
3.4L backfiring through intake
I could really use some advice on this.
I am working on my daughters 1995 Firebird with 3.4L engine. The problem is backfiring through the intake manifold. It is a loud popping sound. I took the car to a car repair clinic for diagnosis. After examination, I was told the valves may be stuck. I replaced the heads with rebuilt ones. The engine still behaved the same. I replaced the timing gears and chain. The engine still behaved the same.
I also replaced the plugs, wires, all three ignition coils. No improvement. But, when you disconnect each spark plug wire one at a time, the backfiring ceases when #5 plug is disconnected. And, I am on my third set of sparkplugs...all are getting gas fouled.
My AutoXRay EZ-Read 2000 (just bought it) says "Vehicle Not Responding" when I try it. So, I haven't seen any trouble codes.
I would appreciate any ideas. I am thinking of checking the camshaft, but I don't really feel that is the problem. Could an injector be bad?
Thanks,
Alton
Old 02-04-2006, 09:26 AM
ROUDA's Avatar
ROUDA ROUDA is offline
Re: 3.4L backfiring through intake
you said camshaft, is just about the only thing left to check push rods to thats all I can think of right now.
Old 02-05-2006, 07:10 AM
The pushrods appeared fine when I was re-assembling. Any other ideas would be appreciated.
I now know the problem with the reader is due to the wrong cable being used. I am going to order one Monday.
Thanks,
Alton
Old 02-05-2006, 11:49 AM
ROUDA's Avatar
when you say back fireing through the intake can you explane that more
Old 02-05-2006, 12:08 PM
It is a loud popping sound that can also be felt when you put your hand on the air intake. Not violent like when the timing is off. It only sounds off when you rev the engine or try to accelerate while driving.
Thanks,
Alton
Old 02-05-2006, 09:32 PM
pro_am pro_am is offline
Send a message via MSN to pro_am Send a message via Yahoo to pro_am
oddly enough i had a bad fuel pump, (long story, more than just pump) and the same problem was happening because i adjusted the timing because i thought that was the problem, just throwing that out there to see if that might help, sorry do'nt have nothing definite.
Jake
Old 02-06-2006, 04:46 AM
Well, I replaced the timing chain and gears. That should have it mechanically timed. But, there is no distributor to turn on this model. So, I wonder if something else is causing the computer to have the engine out of time.
Thanks,
Alton
Old 02-08-2006, 06:25 PM
oooh, i forgot about that? is it throwing any codes, map maybe? or esc? I'm kinda lost, sorry.
Jake
Old 02-08-2006, 09:20 PM
I hope to find out about the colds in a few days. Had to order a special cable because it is a mid '95 GM car.
Thanks,
Alton
Old 02-09-2006, 08:46 AM
badbird8988 badbird8988 is offline
Send a message via AIM to badbird8988
well if it's obd II it will automatically change your timing to what the computer wants it to be... that's why it could be violent when you accelerate
ALL THROTTLE NO BOTTLE
89' FIREBIRD
Old 06-15-2006, 05:46 PM
papasmith papasmith is offline
Thanks,
Alton
Did you ever get this problem fixed and if so, what was the solution?
Old 06-16-2006, 07:09 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
papasmith, please don't resurect old threads. If you have a question pretaining to a topic in an old thread, then simply start a new thread, state your problem, and then the link to the old thread. Thanks.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
