Old 02-04-2006, 06:45 AM
northstar1958 northstar1958 is offline
97 pa headlights
Anyone have any thoughts on why my headlights dim for a split second if i turn on anything electrical while driving, or if i step on the brake, turn on the radio, etc...etc...You can see the headlights dim for a split second...Thanks in advance.
Northstar
Old 02-05-2006, 09:04 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 97 pa headlights
First, take your negative & positive cables loose to check for corrosion. If you find any corrosion, use a 50-50 mix of water and baking soda with a brass brush to clean them, dry with a towel and apply Vaseline to the connections before hooking them back up. After cleaning, Take the car to AutoZone or Advanced auto parts, and have them do a battery load test and alternator output test, and post back.
Old 02-05-2006, 03:29 PM
HotZ28;
Thanks for the tip....The negative battery cable was lose. I cleaned them both and tightened them down, it took care of the problem. Thanks again, I appreciate the help.
Northstar
