Old 02-03-2006, 07:48 PM
lhj lhj is offline
Knuckle removed and installed: wheel problem
I have a 96 Grand Caravan with a lot of mileage 365KM, and I don't want to spend any more money on it so Im repairing it myself and learning at the same time.
I needed to change the front bearing hub on the driver's side. Since it was jammed in, I removed the knuckle to get at it from the rear. I reassembled it exactly like I removed it and the wheel now is tilted out from the top.
I am going to get a wheel alignment but I would like to know what I did wrong for the wheel to tilt like that?
Is there an adjustment I forgot? or is this normal.
Thanks for any help
Old 02-04-2006, 10:16 PM
waltham41 waltham41 is offline
Re: Knuckle removed and installed: wheel problem
Did you bend something? I for one would be interested to hear what the deal is when you find out what it is.
Sorry I can't be of any help with this situation.
Old 02-04-2006, 11:00 PM
lhj lhj is offline
It's the alignment. There are two strut bolts that hold the knuckle and the bottom one is adjustable to control the camber of the wheel. I loosened both and manually aligned the wheel. It looked strait once I tightened the bolts. I now feel safer driving my van to the garage to have it properly aligned.
