At what compression ratio do you need to start using higher octane?
We figured that my compression ration is about 12-12.5to 1. Is that to a point where i'd need more than 87 octane? If not, what is? Thanks again guys!
Jake |
Re: At what compression ratio do you need to start using higher octane?
12:1 compression with iron heads would be ROUGH even on premium pump gas.
LSx series can pull it off...barely. Mine is running 11:1 and requires premium. When it was 10.1:1 it required premium.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
If your compression ratio is that high, you should think about replacing the pistons with dished or something to lower it unless you want to run 110 octane or higher...
