Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-03-2006, 04:54 PM
heymosi heymosi is offline
93 Eagle talon problems!!! PLEASE HELP!!
hi, i have a huge problem with my 1993 EAGLE TALON TSI AWD, 2.0 L turbo. it has been sitting around for about 5 years, i recently recieved the car, got a transmission flush, motor oil flushed, and untill the past few weeks there have been some problems. when i drive it and even before i start it the dash board lights are going crazy like 2/3rds of them. and also when i switch gears and begin to accellerate there is no power but the engine is reving, then 3-5 seconds later it picks up. the car is a manual and it is wierd because when i release the clutch it gets very very little power (like 2 hp just to pull it) then the clutch is fully released then 3-5 seconds later comes the power. is it electrical? is it the turbo? what is it?!!!??!?! PLEASE HELP!!!
Old 02-03-2006, 05:03 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: 93 Eagle talon problems!!! PLEASE HELP!!
Oddly, my gsx has the same symptom sometime. Sometimes after shifting and accelerating it revs higher but doesn't go faster. For that problem maybe a boost leak? My guess would be check for boost leaks, it could even be a clutch problem, maybe even possible transmission problems. Sorry I can't be of much more help. As for your electrical problems...that is freakin wierd.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 02-04-2006, 01:19 AM
well i also forgot to mention that after this incident with all this problem i left the car sitting for about a week. litterally like 7 days later the battery was 100% dead.
Old 02-05-2006, 09:10 PM
SLoe's Avatar
SLoe SLoe is offline
Originally Posted by heymosi
hi, . and also when i switch gears and begin to accellerate there is no power but the engine is reving, then 3-5 seconds later it picks up. the car is a manual and it is wierd because when i release the clutch it gets very very little power (like 2 hp just to pull it) then the clutch is fully released then 3-5 seconds later comes the power. is it electrical? is it the turbo? what is it?!!!??!?! PLEASE HELP!!!
Sounds like your clutch is slipping to me.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 02-07-2006, 12:34 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
If your battery was 100% dead after a week you have a short somewhere. If you have a multimeter you can easily narrow down the problem. Disconnect the negative side of the battery (with everything off, doors closed, and keys out of ignition) connect one connector to the negative battery terminal and the other to the negative cable. With everthing off you should not read more than .05volts (parasitic drain of efi cars) If you have more than .05v pull relays 1 by one until the voltage drops that will isolate the problem.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 02-08-2006, 02:27 PM
turbotalon95 turbotalon95 is offline
you got a bad clutch. i had that same problem in one of my cars, got a new clutch kit and bam.....full power when i realese the clutch. change the clutch.
