Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-03-2006, 05:33 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
PVC IC piping?
Okay so a friend of mine told me that I could just get a FMIC core and use PVC piping for the ic piping. Another friend of mine has a 240sx and did just that. I wanted to get opinions on this. If I decided to do this I would run with the pvc setup for a month or so, then I would use the pvc pipes to go to a muffler shop and get aluminum pipes made.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 02-03-2006, 05:36 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: PVC IC piping?
I supposed it is possible, but don't expect it to dissapate any heat really.
1991 GSX 2.3 Stroker
Old 02-03-2006, 09:40 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: PVC IC piping?
Thats what my friend did on his turbo 420a neon. It works, but not as efficient as metal would be. If you are using it for a temporary, thats ok, but I wouldnt use it permanently.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-03-2006, 10:09 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: PVC IC piping?
Home Depot mod is only a good ideah for Intakes.
DSM geek
Old 02-03-2006, 11:03 PM
joemathews's Avatar
joemathews joemathews is offline
Re: PVC IC piping?
PVC intercooler piping is not a good idea. It would work, but PVC is not designed to repeatedly withstand the beating of being inside an engine bay.
1996 Eagle Talon
Old 02-06-2006, 06:24 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: PVC IC piping?
at high temperatures, PVC also outgasses a gas that can turn into Hydrochloric Acid when mixed with air. ABS plastic (what factory piping is made out of) should be fine, but I'd never put PVC under my hood.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 02-07-2006, 08:53 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: PVC IC piping?
You can get a "universal" ic piping kit on ebay. It's just a bunch of bends and couplers. I'd say the couplers are almost as, if not more expensive than the actual tubing (assuming you'r getting good couplers)
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
