Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 02-03-2006, 03:15 PM
billyo69 billyo69 is offline
Rear plugs
People have said to change the rear plugs on a 3.8 that rolling the engine makes it easier.But how could you do this without disconnecting ALOT of stuff?Exhaust etc.
Old 02-04-2006, 04:20 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Rear plugs
Although it may seem like it makes the job of replacing rear plugs on a 3800 easier it is absolutely not necessary and I believe it makes it harder or at least more time consuming. The biggest problem I have with changing the rear spark plugs is getting the boots off the plugs.
The next big problem is having enough room to remove 2, 4, and 6. I remove the rear engine hoist bracket where the 02 sensor is held on and I remove the 02 sensor. With that stuff out of the way 4 and 6 are easy to get out. IMO #2 is the most tedious to get out but it is a breeze with the right tools.
I never remove the dogbone engine mounts and tilt the engine forward.
To help cure stuck on plug wire boots for the next tune-up I coat the tip and ceramic of each spark plug with dielectric silicone grease.
Timeslip 08/12/06
AF Community Guidelines
Old 02-11-2006, 02:20 PM
micali micali is offline
Re: Rear plugs
on my 3.4 I removed the coil pack and didn't really have any problems getting to the plugs after that. Getting the boots off is the hardest thing. I had to replace mine since I ruined them getting them off.
