I'm getting ready to...
Going to do a tune up on my Impala (2002) with 60,000.
I just wanted to know what Brand name stuff should I get? I have read here before that Frame is not good for an oil filter. Is this true? What should I use? I'm only getting an Air filter, Oil fitler, pcv valve (I think it has one), Fuel fitler. I'm I missing anything? So what brand should I get?????? I'm not looking for High pro. stuff like K&N or anything.. I talking about frame, stp, and some of the others.. Thanks |
Re: I'm getting ready to...
Right.. I just thought for about $3.00 for a PCV and 5-6 for a fuel fitler. I should do it while I'm getting dirty... Thanks for the info on the other stuff..... |
There are alot of reasons not to use AC Delco. I've had good luck with aftermarket products from Fram, STP, Purolator, and others. There is no proof AC Delco parts are superior to any aftermarket product. As a matter of fact other companies make a lot of AC Delco parts and just put their name on the product. For example the 41-101 Iridium spark plugs were made by NGK. Autolite made many of the platinum AC Delco spark plugs. Same is applicable to the filters. Why pay top dollar for AC Delco stuff.
It was bad enough getting a GM car and now I should buy their products to help keep them afloat. I don't think so. Just my two cents. ![]()
well it HAS been proven that the stock GM products like the plugs, wires, coils, etc... are the best option that you have for the car. many companies have tested this and when they make there high HP cars, they still use the stock coil packs and stock wires. they have been proven to have less % of failures compared to any aftermarket parts. they have a awesome temp rating and almost 0 failure rate. even the coils, some people think they shuld get MSD, but no one does really, the stock coils are better then the MSD coils. same goes for the plug wires, more people have had problems when they change to aftermarket then before they did.
so there is no reason to not use them. oh, and there is no interval for changing the fuel filter, just to change it when you suspect its plugged. 60,000 doesnt sound too high for me, its a $6 part and an easy job, I changed mine at like 35,000. and for the PCV valve, the interval is 30,000, its ilke a $3 part and a 5 min fix. Air filter - it depends on what you want, just a replacement one, or a K&N replcement one, the K&N will help air flow better and you'll get a little more power...very little, but still something. and while your doing that you might want to gut the air box while your at it, then you will be an increase in power, plus a nice throaty sound from your exhaust. for oil filter I use mobil, otherwise fram SUCKS. fram anything sucks, in autoshop class they cut apart a fram oil filter and it was basically carboard inside, that was what it used to filter the oil. so if you feel comfortable with using carboard to filter you oil, go ahead. but I would stick iwth either mobil or bosch, or the AC delco. I personally have never used STP products but there not bad. they are better than fram and not as good as mobil. |
As to whether Fram sucks is a matter of personal opinion. I've been using Fram products for 30 years. I have not blown an engine yet. I trust Fram enough to run it in my GTP at the dragstrip three years running. I even used Fram products in our '01 Impala LS up until we got rid of it. It did not crap out because of using Fram either. It went because of reliability problems with the CAT, transmission and some electrical problems. You know typical Impala problems. BTW - Fram is a division of Allied Signal which also owns Prestone and Autolite. And Mobil filters are actually made by Champion Labs. See links below: Here's some interesting independent info on oil filters: http://minimopar.knizefamily.net/oilfilterstudy.html http://minimopar.knizefamily.net/oilfilters.html
'08 Pontiac Grand Prix GXP (Dark Slate Metallic) - LS4 5.3L V8 '02 Oldsmobile Alero GL2 - LA1 3400 V6 '99 Buick Regal LS - L36 Series II 3800 V6 '03 Honda CR250R MX - 2 Stroke 250cc '97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged (Sold) Timeslip 08/12/06 AF Community Guidelines Last edited by BNaylor; 02-04-2006 at 11:43 PM. |
41-101 AC's made by NGK....Probably correct since they are made in Japan and if NGK is cheaper at the store.., I have no problem with that. K&N filter is a good filter and lasts forever and you do save $ over time, 6 years, 100k,the big but on this is that many DIY'ers, not all, apply over oiling after cleaning and that is where problems can occur. The PVC, yea they are cheap and if you have money to toss fine. If it rattles freely however, there is no need to change it. Fuel filter should be good 100K but if you want to change it at 35-60K that is fine if you suspect there is a need. More important to attend to at 60K, is Trans fliud and filter change. Note: most trans tech pros I know do not recommend flush type trans service. Their reason being the movment of metal particles from where they have settled safely to where they should not be during the process due to the high detergent content of trans fluid. Four to five qts from dropping the pan and filter change is sufficient and recommended by mfg. I would put my money there, but this again is my opinion.
Thanks for the heads up on the amount of fluid for change out. I have yet to do mine, due this July. I decided on a 60K on advice from trans tech I have do my work. Gettin to old for this messy job....
