| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
Proformance Chips
Do you guys know anything about upgraded ECU chips? I heard it is pretty good bang for your buck? Any information would be awesome!
Re: Proformance Chips
research, there is many posts on here. but to answer your question yes ecu upgrades are phenomenol for the z performance. check out stillen.com and jim wolfe technologies. they both make good ones, its def,.worth it
Ash spec ECU, which Ashley Power's himself sells and Z1 sells is the cheapest ECU upgrade worth looking into. and yes, WITH a boost controller or boost jets the ECU upgrade can result in a 60hp gain.
ZedEx Crew Member #4
ya you are right
I wouldn't recommend getting a chip till you're done getting what ever done to your car that you're going to because the work that has been done to your car has to be taken into account when the chip is programmed to make the most of it.
They have a Romulator for the Z32?
Who cares what's in your wallet...what's in your garage? ![]() VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31 Hope you can see the tiny pic...AF reduced the size limit! Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
does ash reburn z31T computers or what??? I'm scared shitless of a romulator program
Georgey on the subject of midget beastiality pornos Quote:
R.I.P Andy, you will be missed by all. |
romulator is scary shit man...delerious told me something about hexidecimal and i have had a few convos with Ash and he explains it where i dont understand. i will learn gradually some day but right now, i am getting chips burnt and then take it and getting it dyno tuned professionally.
Im going to get a Jim Wolf ECU in a couple weeks. are there any down sides to this ecu?
1997 Eclipse GS-T Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head- Interior Modification:-Autometer Boost Gauge http://www.cardomain.com/id/xTeamRedLine23x |
save yourself some money...trust me, its the same thing. he stands by his work. and everything that has came out of Z1's shop is using this ECU http://ashspecz.com/index.htm
hex isn't that difficult, you just have to sit down for a while and get your head around the concept of different numbering systems and you're good to go... anyway, i wouldn't use the romulator, and i'm not going to, as i have the power to reprogram, reflash, and reinstall any EPROM program i want for whatever setup i'm running.... no messing with wires, no messing with an s-afc, just a decent wideband o2 sensor with a datalogging capability if so desired, and i'm golden... it's amazing how easy something that sounds so complicated can get with just a few hours of reading...
that is, of course, for the z31 that nobody seems to want or like... for the z32 i'd stick with a professionally programmed chip and pay out the ass for it... like you do for everything else on the z32..
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
I'm goin romulator all the way, man... Unlimited tuning possiblities instant, real time results datalogging (I think...) cheap It is a bit complicated till ya learn it (I definately don't think it's for everyone) but I'm good with numbers and math (I too have read up on it a bit) so I'll be ok I already have a laptop so that solves that problem Just depends on what you're looking for. I wanna be able to get my setup dialed in to the max. With an ECU you buy from somewhere, you tell them what you have done and they set up the computer for your car. I can't imagine this being the best route when you have a heavily modified or completely custom setup. Sure...if you have a Z32TT (or Z31T...whatever) with an intake, exhaust, boost controller set at 14 psi and wanna add an ECU, getting one from somewhere isn't a bad idea but I just don't think this would work as well for me. With the romulator, I can set it up my self so I KNOW it's to the max. I can't imagine being able to get my setup 102% perfect with a plug and play option like a purchased ECU so I am going to 'make my own'.
did you know if you boost higher without changing the ECU you will actually get better performance but you run the risk of detonation on the slightest variation. his is because not letting the ECU that you are boosting this high will cause the A/F ratio to lean out giving it better performance. but is leaning out your A/F good, no. it will eventually destroy your motor, what if it gets colder you and you ahve it tuned on the edge. not safe...this is why there is an ECU in the first place. to keep your prize possession from blowing up in your face... and for you to tune your system yourself to the degree that you are speaking would take many dyno pulls and hours of tuning. dyno tuning is expensive...and if your doing it yourself dont forget to make a couple 5th gear pulls so you can set the A/F ratio for long cruising in comparison to other gears. many tuners do this because you usually dont do 5th gear pulls on the dyno... it is a much more cost effective method for someone to buy a S-AFCII and a program from a company and spend a a couple of hours on the dyno fine tuning your performance on the AFC and letting the ECU keep it within most things within safety. this would be in comparison of spending thousands on dynos... my ![]() Do yourself a favor and buy a ECU program from a company...then get a tuning tool that will save settings (S-AFCII) and then get a wide-band O2 sensor wih a digital readout monitor (Can be had for under $300). with these tools you can tune your car to anything you want without having to buy a program and accessories to burn your own chips and risk making the slightest mistake. there is actually a group buy over on TwinTurbo.net for the wideband set-up i am speaking of above, right now.
I know it's a lil' late, but the JWT ECU's have been known to run a lil' rich on the z31T's...
its not overly rich, slightly...call them, they will explain to you why, how, where, when, why...
