Old 02-03-2006, 08:08 AM
eeezeegoin76 eeezeegoin76 is offline
Send a message via Yahoo to eeezeegoin76
Angry only high on heater blower
got a 2002 grand prix GT the first 4 speeds for the heater blower are dead,....high speed is all I got,eather freeze or roast.any ideas on where to start looking ...........thanks
Old 02-03-2006, 08:13 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: only high on heater blower
you need a blower motor resistor, AC-Delco part number 15-80571. IT is located in the heater box, and you'll have to remove the blower motor to replace it. Not a bad job, just a pain standing on your head, as the blower motor is under the dash, passenger side.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-03-2006, 08:23 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Another victim of the dreaded blower motor resistor!!! You would think that GM would move these things out of the duct work or put in a quick change version as often as they seem to fail. I know they redesigned them but the failure rate seems to be quite high!
Old 02-05-2006, 08:21 AM
Prix 2002 Prix 2002 is offline
Hi I am a new member, I am having the same problem. I drive 2002 prix with a 3.8 engine. My heater only works on hi. I am so glad I came upon this forum. I just wanted to say thanks for the information.
Old 02-05-2006, 09:57 AM
Pontiac Guy
Welcome to the forum Prix 2002! This is a great forum for the DIY'er as well as anyone interested in cars in general. There is a lot of experience here so if you have a question don't be afraid to post.
Old 02-06-2006, 09:05 AM
richtazz's Avatar
Welcome Prix 2002, as GTP Dad stated, the more the merrier. Lots of knowledge and help on here, we welcome your questions and input.
Old 02-06-2006, 01:46 PM
Wink Re: only high on heater blower
Thanks Buddy,you saved me a lot of time and money,you know your sh__. Thanks again.............
Old 02-07-2006, 08:19 AM
richtazz's Avatar
you're very welcome eeezee, that's what we're here for.
Old 02-08-2006, 11:02 AM
pontiacinsane pontiacinsane is offline
Thanks to this thread, my husband was able to fix this very problem--and he didn't have to remove the blower motor to do it. He was able to to get in under the glovebox through the access panel (somehow snaked on around the motor) and did the job in under 30 minutes. So cool! Basically he pulled the glovebox light up in the area to see what was what too. (We didn't have a flashlight with batteries that worked). Thanks to the guy that posted the pix showing the old and new resistor as well as where to find the damn thing. Very cool.
Old 02-12-2006, 08:15 PM
troy.s. troy.s. is offline
ok, thanks from me as well. i had the same prob, thanks for the help.
Old 01-01-2013, 11:15 AM
jdaugherty88 jdaugherty88 is offline
I am having similar problems, but replacing the reisitor didn't fix them. The blower only runs on high and the headlights go out when the fan speed switch is set from 1 thru 4. If I disconnect the leads that go from the resistor to the blower motor, the lights will remain on thru all switch settings. With the blower motor disconnected, I can hear a click from from the resistor when transitioning from fan speed setting 4 to 5 (high).
Any other recommendations to resolve this problem would be greatly appreciated.
Old 07-07-2013, 02:54 PM
Joedwnsouth Joedwnsouth is offline
I had the same problem....Its your Ignition control switch..... changed it out and all settings work
Old 07-09-2013, 06:51 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
The above suggestion is correct. The ignition switch in your car is bad and is causing such electrical gremilns.
There is a How-to in the tech articles sectino of this forum.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 01-24-2016, 03:25 PM
00 GP GT Coupe 00 GP GT Coupe is offline
My blower motor also only woks on 5. Nothing on 1 thru 4. Also my headlights still work when I try heater blower on 1 thru 4. So what do I need to replace? Thanks for any help.
Old 01-24-2016, 03:27 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Blower motor resistor is your issue
The Following User Says Thank You to Stealthee For This Useful Post:
00 GP GT Coupe (01-24-2016)
