Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 02-03-2006, 07:18 AM
seasonpowell seasonpowell is offline
help with 98 sunfire 2.2
The car starts and runs but when you try to put into gear it makes a grindinG SOund
Old 02-03-2006, 12:20 PM
|WYG|SS |WYG|SS is offline
Re: help with 98 sunfire 2.2
tranny is probably shot. thats wut im guessing. check the trany fluid maybe it empty.
Old 02-03-2006, 12:53 PM
GTP Dad GTP Dad is offline
Pontiac Guy
First of all is this a manual or automatic? If it is a manual the clutch may be bad or out of adjustment. Usually automatics will not grind even when bad. Also the manual may have a bad syncronizer that is causing this problem if so it will need to be taken apart and repaired. If it is an automatic take it to a shop and have it checked with a trans capable scanner. That should give some indication as to what is going on. Good Luck and Welcome to AF!
