Go Back   Automotive Forums Car Chat > Toyota > Supra > Maintenance
Maintenance Have questions? Find answers. Help out fellow Supra owners.
Old 02-03-2006, 03:01 AM
love2drift's Avatar
love2drift love2drift is offline
Send a message via AIM to love2drift Send a message via Yahoo to love2drift
Angry 1988 Toyota Supra wants to be driven into a river
Ok people don't get me wrong I mean I love My Supra Turbo with only 65000 miles on it. On the bad side it is auto but hey you can't have every thing any way I NEED HELP!!!! Ok so when I go to start my car up it kinda runs rough but after a min it revs up and becomes calm but today wen I left work it was rough wen i started it and as I was waiting for it to warm up it started goin to low rpm's 400-600 and jumping around almost turning off but i gave it gas and it went back up and was still kinda rough not to mention earlier today wen I drive it every things fine it's wen i apply the breaks that it kinda goes to shit. I hit the breaks and the needel moves up and down at around 500rmps and the check engine light comes on so i put it in nutral and it's fine some times, but if I leave it in drive and the needel moves around and the car will shut off and I'll have to put it in park and restart it. I'm scared that one day it wont start up but so far it starts up again well any way I drove it to work today and saw a red light so i put it in nutral and the rpms started acting funny so i tried to give it gas but i was to late i was still rolling and turned the key and it started up again I don't know this shits confusing a friend of mine said it might be the crank case sensor and some people on the forums that had some wat of the same problem said it was one of the ground cabels loose and don't know if any one can help me PLEASE DO Because I Love my Supra and don't really wana get rid of her THANKS GUYS MIKE
Old 02-03-2006, 03:20 AM
zax89 zax89 is offline
Re: 1988 Toyota Supra wants to be driven into a river
check for vacuum leaks; get your car to idle(if it will) and spray your vaccum lines with carb cleaner and when you spray a line and it changes the rpm consistenly replace the line or lines.
my cardomain
Old 02-03-2006, 06:03 AM
TcmaBoy's Avatar
TcmaBoy TcmaBoy is offline
AF - Advisor
If you are getting a CEL then you should pull the code. It might be the mass air flow sensor, vac leaks, or an ignition problem.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
Old 02-04-2006, 04:23 AM
love2drift's Avatar
Thanks alot for all U'r help guys
Old 02-08-2006, 10:52 PM
love2drift's Avatar
well guys i found the prob it was the BVSV one of the hose was off
Old 02-13-2006, 03:59 AM
love2drift's Avatar
well I was wrong it started up again i ran the self diagnostict tool http://www.cygnusx1.net/supra/techti...rrorcodes.html and found out if was my AFM so hey i guess it's a good reason to get a lexus AFM hahaha gata love it thanks again guys
