won't start
I have installed a new battery, new starter, and a new alternator, and still when I turn the ign. nothing happens. No click, no nothing. But as soon as I boost it with cables to any running vehicle, the car will start and run. I ran it it for 30 miles. Yet when I turn it off, it will not start again. Not even will the solonoid to the starter will click. Any suggestions.
Re: won't start
1st suspect I would go for is that "new" alternator. I put one on one time.....and it was bad from the start. Any lights on before this happened? Bet that little yellow light was on huh?
What I would do is get the new Alt checked......the battery would have ran the vehicle for a while....but after that....would be dead as a door nail. By the way...IF the alt is bad.....take the batt back too.....you run a batt down that low and it will never....ever be the same. Good luck |
Re: won't start
had both checked before purchasing. all good!
Re: won't start
What year is the car....miles....etc
Re: won't start
Where are you hooking the jumper cables up?
Re: won't start
1994 grand prix 3.1. jumper cables were hooked up to 1. 1994 ford e150, 2. 2003 chevy 1/2 ton, 3. 1994 ford e150
Re: won't start
oh, by the way, the mileage is a lil above 157,000.
Re: won't start
Did you hook directly to the battery on the grand prix or the post above the fuse box?
Re: won't start
directly to batt.
Re: won't start
Do you have a volt meter?
Re: won't start
yes i do
Re: won't start
What is the voltage of the battery....have you tested it?
Re: won't start
voltage before hokking eveything up was 12.64. any way to comm. quicker?
Re: won't start
You need to check the voltage now....since it wont start at this point. I need to know if the battery has voltage. Do the lights come on? Try the headlights....and then test the voltage while they are on.....this will help diagnose the problem
Re: won't start
I gotta hit the sack...but if you will provide this info....I will get back to you tommorow.....you have a simple problem.....just need more data to break it down
