Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-02-2006, 08:01 PM
iama10spro007 iama10spro007 is offline
Fuel Problem
I own a 89 CV LTD. Its been sitting in my driveway for a three months. I had to recharge the battery. After doing so, the car would crank but not turn over. I am not smelling any gas, and when I checked the fuel pressure valve, no gas is coming through. Is there a fuel shut off swith anywhere?? Or could it possibly be a fuel filter?? Anyone with information would greatly be appreciated.. THanks in Advance!
Old 02-02-2006, 08:50 PM
amo4387622 amo4387622 is offline
Re: Fuel Problem
In the trunk on the drive side near the trunk lid hinge is a small black box with a red button on the top that is your fuel pump shut off switch the swith should be pushed down for the pump to work. If the filter has not been changed I would change it.
Old 02-02-2006, 10:51 PM
Re: Fuel Problem
Ok.... so its not the fuel shut off switch.... Any other suggestions?? I was hoping I wouldn't have to change the fuel pump becasue of its location which I believe is on top of the fuel tank.. I am sure it will not be a cheap repair being that I am trying to sell the car without having to add too much money to it. Please Help!!!
Old 02-02-2006, 11:27 PM
Re: Fuel Problem
When you turn the key on but engine not running do you hear the fuel pump come on to prime the fuel lines? Do you know if you have spark? Also I would check for blown fuses under the dash and under the hood. And yes the pump is on top of the tank.
Old 02-03-2006, 12:13 AM
Re: Fuel Problem
Yes my hand is still burning from the spark (jk) and no unfortunally I do not hear the fuel pump priming the lines. I've checked the fuses under the dash, but perhaps it may be a relay??? Not really sure where to check under the hood for other fuses.
Old 02-03-2006, 07:05 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Fuel Problem
the relay is on the drivers side down by the radiator. It should have a green base on it.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-03-2006, 11:23 AM
Re: Fuel Problem
Ok way2old,
I have located the green relay on the driverside by the radiator. I removed the relay and it appears that there is a good amount of corrosion on both the wires leading up to the relay, and the relay itself. Could the corrosion be a cause to why the car isn't getting any gas?? I am not really sure on how to check to see if the relay is blow or not..
Old 02-03-2006, 12:43 PM
Re: Fuel Problem
Yes if there is corrosion on the wires it will effect the pump from getting all the voltage it needs to run. And as for the fuses under the hood they are in a black box on the driver side fender close to the brake booster. and one of the ways to tell if the relay works is have someone turn the key to on position and while holding the relay or it in the car you should be able to her a click. If no click the relay is no good.
