Old 02-02-2006, 07:50 PM
Shinichi's Avatar
Shinichi Shinichi is offline
WIP: Initial D RX-7 A-SPEC W/ MS-02 Rims
Well, i've been working on this for a while now, but i can't seem to figure out a way to lower the front. the rear rims were just right but the front is just totally out of proportion. does anyone have any tips or how you would go about lowering the front on this kit? thanks
Here are some pics
Old 02-02-2006, 07:54 PM
Shinichi's Avatar
Re: WIP: Initial D RX-7 A-SPEC W/ MS-02 Rims
oh by the way, for any of you making this model, after messing up kyoko's version of the FD, i discovered that the decal for the center console does not seem to align perfectly to the grooves on the actual part when setting it. therefore i cut each part of the decal out and individually set them on the part. from what i've seen it comes out much better that way
Old 02-02-2006, 09:08 PM
Feint Motion's Avatar
Feint Motion Feint Motion is offline
Paint job looks good. Very Clean Interior too.
To lower,just scrap the suspension struts, glue the brake a little above the axle, then glue the wheel.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Old 02-03-2006, 12:10 AM
0tobe60in10minutes's Avatar
0tobe60in10minutes 0tobe60in10minutes is offline
Send a message via AIM to 0tobe60in10minutes
looks really nice. i actually have seen a 1:1 rx-7 running around here lookin like that, except it was red. nice car so far thought, i like the black line inbetween the bumper..gives it space..
RIP 88 Bronco II
Old 02-03-2006, 12:15 PM
Myx_85's Avatar
Myx_85 Myx_85 is offline
Send a message via MSN to Myx_85
I think try this: How To: Lowering the ride height
Old 02-03-2006, 04:09 PM
Shinichi's Avatar
Originally Posted by Myx_85
i saw that, but the suspension is different on this model kit. dang. has anyone done a lowering on the fujimi rx-7 before?
i want to make it so that the wheels can turn after the model is completed too
The body isnt painted yet if youre wondering. i still havent gotten around to buying the yellow paint. does duplicolor have mazda colors? i went to the local canadian tire and they only had toyota yellow. is that yellow similar to the tamiya yellow?
Old 02-04-2006, 07:05 AM
Myx_85's Avatar
Ok, look, try this, i think it works!
Cut off in the red line, and glue together...
This is my idea...
Old 02-04-2006, 07:35 AM
G-man422's Avatar
G-man422 G-man422 is offline
looks good.
Old 02-04-2006, 07:48 AM
SAABPOWER's Avatar
SAABPOWER SAABPOWER is offline
Send a message via MSN to SAABPOWER
Looking great so far. Good luck with the lowering of the car.
Current project/projects:
*Nissan Skyline R34 GT-R
*Shelby Mustang '66
Planned projects:
*Scania 4-serie Topline showtruck
*A car or a truck, don't know yet
__________________________________________________ ___________
Click on this link to check out my simple projects: Here
Old 02-04-2006, 06:21 PM
Shinichi's Avatar
This is my idea...
cutting off the struts i got but im worried about part A2. from what i see, it'll be to high to glue onto the shornened strut? would i have to bend the plastic piece on the ends for it to fit the assembly?
Old 02-04-2006, 06:27 PM
SHIFT_drift's Avatar
SHIFT_drift SHIFT_drift is offline
yeah, im pretty sure if you were to lower it by cutting the strusts that you would have to bend the linkages on A2.... or cut them and glue them back at an angle so it fits... not quite sure...
SHIFT_drift
complete:tamiya.180sx.custom.widebody
complete:fujimi.nissan.sileighty
complete:hasegawa.toyota.celica.1600gt
complete:fujimi.mazda.rx-7.fd3s
complete:revell.datsun.510.chop.top
in progress:57.chrysler.300c.convertible.slammed
next:tamiya.nissan.skyline.2000.gt-r
Old 02-05-2006, 08:50 AM
Myx_85's Avatar
This is your A2 part:
Do this...
Old 02-07-2006, 05:00 PM
Shinichi's Avatar
well, i finally lowered the car, thanks to Myx_85's idea of cutting the struts shorter. however the A2 part i did not want to spend time cutting so i made them fit by heating and bending. here's the results:
BEFORE:
AFTER: the back was lowered 1mm and the front 4mm
Old 02-07-2006, 05:07 PM
G-man422's Avatar
It looks great, i love the rims.
Old 02-08-2006, 05:52 AM
REXtreme7's Avatar
REXtreme7 REXtreme7 is offline
A bit late but the above method is not needed
See mine.
Its pretty easy
http://www25.brinkster.com/Rextreme/...dels_LowFD.htm
I have just a few FD models... HAHA
http://www25.brinkster.com/REXTREME/REXTREME_Models.htm
This instruction sheet is for AOSHIMA but may give some more ideas.
