Old 02-02-2006, 07:22 PM
blazer00 blazer00 is offline
2000 Blazer no start
Alright i really need some help here... So last week i couldn't get the blazer started so i first changed out the spak plugs and wires ,cap and rotor. no luck...
left it sit over night and it started right up. So i changed out the fuel filter witch
was clogged with this black maple syrup lookin stuff. It was working good for about a week, now today i coudn't get it started, my fuel pump is not comming on when i turn the key i alredy checked the relay and my check engine light is on.......any suggestions on what coud be the problem?
Old 02-02-2006, 07:44 PM
maxwedge maxwedge is offline
A990 racer
Re: 2000 Blazer no start
If you had syrup like stuff in the filter better pull the tank out and see whats, what!
Old 02-03-2006, 06:35 PM
Well i figured it out...........the fuel pump was def. dead i put a new one in today(only 4 hours of work! ) I have one question though when we looked inside the tank there was a green ball a little bigger then a ping pong ball floating inside the tank. I have no clue what this ball is or if it should even be in there. Does anyone know anything about this?
2 door 2000 blazer, 146,000miles
Old 02-04-2006, 09:16 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
It probably came out of the filler neck. The ball is a check valve ball. This allows gas into the tank, but prevents gas from going back up the filler neck.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
