Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 02-02-2006, 05:24 PM
InnerDragon103's Avatar
InnerDragon103 InnerDragon103 is offline
Send a message via AIM to InnerDragon103
How to get that nasty film off your plastic headlamps
Hey all, i too am plagued with old worn headlamps that you cant see shit out of... so i decided to try something on my own, and it seems to have worked, and it didnt cost me anything:
i took steel wool (NOT the really thick coarse one, but the one made out of fine strands of metal, strands about as thick as a strand of hair) and some water with soapy solution in it and scrubbed the hell out of my headlamps... i mean i at least spent 20 minutes on each scrubbing and scrubbing to make sure i got it all off... You'd be amazed at how well it actually worked, all this sediment and brown stuff came off, and i could see the inside of my light!
Then, i dried them thoroughly and sprayed WD-40 on them and rubbed that in, really helped out. The WD-40 is like a temporary fix though; it'll eventually wear off, espically because of rain and whatnot, so my friend said the next step is to buy scratch remover compound for plastics and buff that on... I haven't done that yet, but the first parrt with the wool and the WD-40 has helped my visibility so much, and i found these things around my house, so i havent spent anything on the job. Trust me, just go out there and scrub scrub scrub... You'll be amazed at how well this works on those yellow fogged up lamps.
~1994 Altima GXE 5 speed~
Current mods:
Short Ram Intake
Tint
8500K headlights
New sound system, 2 12" subs (600W)
Old 02-02-2006, 05:32 PM
somick's Avatar
somick somick is offline
Re: How to get that nasty film off your plastic headlamps
Very interesting thing. I should try it too.
Just recently I received a coupon from the dealer for my son's 98 Plymouth Neon for the "Lights restoration". They wanted 127 dollars. I never called them so do not know what they wanted this money for. Anyway, this is well worth to try.
Thank you,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 02-02-2006, 06:39 PM
jserrano jserrano is offline
Yeap, I'm a firm believer of WD-40 as well.
Old 02-04-2006, 04:53 AM
venado123 venado123 is offline
I tried tons of different things and none of them worked that well. The best way is to look for aftermarket asssemblies and replace them. I found some at a knock off place for about 55 per side! Or you can get really bright headlamps.
-v-
