Please Help Me
Hey i have a 1993 PI Crown Vic and my cruise control and horn has stoped working.... how can i test this or fix this....
Re: Please Help Me
Check the cruise control module. Pin 6 and pin 10 are grounds. The ground wires run over to the fender to a small bolt. If these grounds are not good, the cruise and horn will not work. Funny I inow, but Ford runs the horn ground through the cruise control module.
Being way2old is why I need help from younger minds The sooner you fall behind the more time you'll have to catch up. ![]() HEY Y'ALL--READ THIS Here are some of our old vehicles for sale.
Re: Please Help Me
They also use the same fuse. Check your fuses.
BMFer1
Re: Please Help Me
thanks way2old...im going to check this and try 2 fix my problem....
Re: Please Help Me
On the inside of the driver side fender, there are a few wires bolted to it, one of those wires is the ground for the horn, check your connection there.
![]() His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels. ![]() Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps. |
Re: Please Help Me
Is your air bag light on? Under the wheel is a clock spring or sliding air bag contact. If it is faulty the horn and cruise will not work. The wiring for them goes through the clock spring.
enjoy your freedom? thank a soldier
hey if my air bag light is not on constantly could it still be what you are talking about....b/c i checked my ground conections and they are tight...and before i re-run them i want to explore all of my options...
Re: Please Help Me
It is possible, but if the light is not on you may have wiring issues.
