Go Back   Automotive Forums Car Chat > Oldsmobile > Achieva
Old 02-02-2006, 01:59 PM
ttbnate ttbnate is offline
Idle problem
I've got a 92 Achieva with the 2.3L 4 cylinder. After the car warms up, the idle will raise to about 1600-1800.
I've noticed that this is a degenerative problem, and over time it is taking less and less time for the idle to start going out of control.
...anyone have any ideas as to what could be causing this?
Old 02-02-2006, 07:54 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Idle problem
Welcome to AF!!
Check for a vacuum leak either a bad hose or around the intake manifold. Rising idle like you indicate usually indicates that there is air entering the engine at a place other than it should. Also check the throttle body and make sure it is tight, that can cause this type of problem. The other is a bad throttle position sensor. If it is sending the wrong voltage to the ecm it will cause idle to be too high.
