Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 02-02-2006, 01:27 PM
ffcohpin ffcohpin is offline
maxima vs altima 3.5 se
I'm thinking of getting a new car...
I decided to go with nissan's v6 engine.
which one should I choose?
maxima se vs altima 3.5 se...
which is faster? which handles better? anything else I should know?
Thank you.
Old 02-03-2006, 12:53 AM
altimaracer altimaracer is offline
Re: maxima vs altima 3.5 se
they started putting the vg35's in later 01 maxima's with a 6 speed, 255hp, but altimas only get a 5 speed and the engine is not tuned well only making between 240 - 245< this depends on the year.. the ser altima produces 265 but the maxima which, looks more appealing produces the same hp,now all that matters is the year u want the car in and how much u have to spend.....
(also from 02 and up both the altima and maxima get 5 speed automatics, if this helps)
Old 02-03-2006, 12:24 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
Altimaracer, your specs are a bit off.
it's a VQ35 not a vg and it was in 02 that they started putting them in the maxima's, not 01. SE-R altima's are 260 hp, the maxima is 265, but they packed on a bit of weight in the SE-R putting it a whole 135 lbs heavier than a 5.5 gen 3.5 maxima. Also the maxima didn't get a 5 speed automatic as standard equipment until 2005, it was only an option in 2004 and didn't exist before that in max's, and the altima never got a 5 speed auto except for in the SE-R, all other altima's use a 4 speed automatic.
as far as the Se-R, i can't see any real justification in buying an SE-R altima over a 2002-2003 3.5L maxima. for the extra $12,000(minimum) you'll spend on the altima you only get 5 more hp and an IRS, other than that the car's are almost indentical.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
