New To Board
Hey everyone....I have a 2001 Eclipse GT Spyder that I bought in June of 2005. I absolutly love this car. Here is what I have done so far for upgrades. I have an AEM Cold Air Intake System, New 17" Rims, High Performance Drilled and Slotted Roters (Just put in Yesterday). I just ordered a Centerforce Stage 2 Clutch and a Fidenza High Performance light weight flywheel. I have also changed out the underdrive pully to a AEM light weight pully. Does the short shifter really make a big difference? Can you all give me some ideas on what I can do next to increace power. I am getting ready to order a new Magnaflow Exhause System as well. I want more speed lol. Once I learn how to use this board, I can and will post pictures of my ride. Hope I get some good responces.
Dan |
Re: New To Board
welcome.
Re: New To Board
Thank you. Looks like you have some nice things on your ride. Hey I am am having my new centerforce stage 2 clutch and fidanza 9lb flywheel put in next week. Is there anything that you would recommend I do while they have that stuff out. Trying to save money.
Thanks, Dan |
Re: New To Board
I'd get a LSD and have them all 3 put in at the sametime.
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads. |
Re: New To Board
Ok call me stupid, but I have no idea what an LSD is? Can you explain to me what that is so I can order one.
Re: New To Board
besides that welcome to the board ![]() LSD : Limited Slip Differential, basically makes sure both wheels turn at the same rate to prevent a power wheel, or torque steer also certain companies will replace their differentials for free and are built for racing
![]() Don't act like you don't love it.
503/2000 |
Re: New To Board
Re: New To Board
As for the short shifter, I have the B&M and it helps alot. It isnt that much shorter between gears (like from 1st to 2nd), but the lateral throw is shorter (it is much str8ter from 2-3, the stick centers itself when its in neutral so 3rd is like straight up). There isnt a whole lot you can do performance wise that will make a big dif. unless you want to put some money into it. You are on the right track with the flywheel and clutch, exhaust and intake. An LSD will not add power, but it will lower your 0-60 time because you wont get as much wheel spin, poly motor mounts will also help with feel.
2000 Fed. Spec GT-"Lafawnduh" Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp |
Re: New To Board
Thanks man for the advise. I think I will get a short shifter for my car. I can't wait to see the difference in the car when I have the clutch and flywheel put in next week. I think I am going to work on looks just as much as power for my car. I like the sound system that you have in your car and I will have to work on my soon.
MODS: 2001 Mitsubishi Eclipse GT Spyder,17" Konig Wheels, AEM Underdrive pully and Air Intake System, B & M Short Shifter with MOMO boot & shift knob, High Performance Drilled & Slotted Roters w/Hawk Brake Pads, Centerforce Stage 2 Clutch, Fidanza 9lb Flywheel and a Magnaflow Full Catback Exhaust System. |
Re: New To Board
You notice any improvement with your underdrive pulley? I kinda want to put one on, but with my stereo i cant afford to lose any alternator power. Also, I havent really heard anything from anyone that has put one on.
Re: New To Board
I was told the purpose of the underdrive pully was to ellimate drag. I have noticed that I don't have much drag when the a/c is on. Other then that it's just lighter then the stock one and increases a little bit of the power. I have no complaints with it so far.
Re: New To Board
as for the shortshifter, i also have the B&M and i love it, but say goodbye to putting things in your cupholder, cuz if you do it'll be awkward driving also energy suspension shift bushings made a very big difference by themselves for shifter feel, so definitely get those while your at it
503/2000 |
Re: New To Board
That could explain why my check engine light came on for no reason. I did take it into the shop and he said it was the oxygen sensor. They could not find anything wrong with anything so he just reset it and so far so good.
Re: New To Board
how would pulleys throw a code on an o2 sensor... ?
503/2000 |
Re: New To Board
I wansn't sure if that is what caused it or not I was just guessing. You would probably know more about that then I would. Could of been something else. But that problem seems to be fixed now. I got my Fidanza flywheel in today and will have my new clutch and flywheel put in on Wednesday. I can't wait! Right now it seems like the clutch is slipping just a bit and can't wait to get all my power back. I want to order those 14000 (what ever) headlights for my car. I think that will be next. Probably order those this weekend. Those sound very nice. Dan
