Old 02-02-2006, 01:11 PM
lucy1030k lucy1030k is offline
1981 camaro dash
Does anyone know if the dash from a 1980 is the same for a 1981?
Thanks
Old 02-02-2006, 05:25 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: 1981 camaro dash
The cluster or what are you asking? If its the top where it gets cracked then yes.
Old 02-02-2006, 05:41 PM
Yes, I am just referring to the actual dash, not the instrument cluster. I am needing to replace my dash in my 1981, but I am not sure what other years will fit.
Thanks
Old 02-02-2006, 05:46 PM
Is eating.
Well I dont know much about 2nd gens but im sure there are some differences because of the A/C vents or something.. have you looked for it at yearone.com? or other parts site? Also there isnt a difference between 1980 and 1981, but ofcourse the difference will be between the A/C vents having one or not. So look around.
Old 02-02-2006, 05:56 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
dash is the massive assembly in the front of the cabin... are you talking about dash or dash pad? dash pad is usually what will get sun damaged and crack... if you're talking about dash pad... then i'm pretty sure they are the same
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 04-21-2006, 10:22 AM
dozerdogg dozerdogg is offline
they are the same .its just one big piece and its not that hard to swap .good luck
Old 04-21-2006, 10:29 AM
heres another option.they make a cap for those dashes that fit over the top of the old dash.it takes about 5 minutes and looks great i've got on in my '79 z-28.it only costs about $80
