Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-02-2006, 10:16 AM
bbellster bbellster is offline
96 CV Temperature Gauge
My temp gauge is not working. Can someone outline a trouble shooting procedure to determine the cause? I did notice that there seems to be two sending units, which one goes to the gauge? Can I find the problem with a simple multimeter?
Thanks BB
Old 02-03-2006, 09:57 AM
No takers?
Surely someone has had some experience with this??? What I'm looking for is a resistance value for the sending unit and a voltage I can apply to the gauge to see it they are functional. Also, could this be some kind of a computer problem?
bb
Old 02-03-2006, 01:01 PM
ModMech's Avatar
ModMech ModMech is offline
Re: 96 CV Temperature Gauge
The sender with a single wire is for the gauge, the two-wire one is for the PCM.
Ground the single wire, the gauge should go to full hot. Remove it from ground and the gauge should go to full cold. If not, there is a wiring or actual gauge problem.
