Old 02-02-2006, 09:25 AM
kmschna kmschna is offline
Right Front Tire Feathering On Inside
I just gave the first rotation to a new set of tires and notice that the right front tire has feathered a little on the inside. Not "too" bad, but enough to get my attention. All other tires normal. Steering normal. No curbs or anything like that.
Front end allignment problem or do you think a suspension/steering part is worn?
BTW. That wheels lower ball joint has a torn greese boot, but I keep it pumped up often.
2000 Silver 5.3 2WD 95K
Thanks for any insight.
Old 02-02-2006, 09:36 AM
wafrederick wafrederick is offline
Banned
Re: Right Front Tire Feathering On Inside
You mightwant to get a front end alignment done.Get the front end checked first for worn suspension parts and get a second opinion.Some like to replace parts that they say are bad and they are wrong sometimes.I know this part,one place likes to replace balljoints that are not bad.
Old 02-02-2006, 09:55 AM
Exactly what I been thinking. I am trying to arm myself before taking it in. All to often, one has work done on the suspension and it turns out that it just needed an alignment or visa-versa. Wa'la double bill.
Old 02-02-2006, 07:34 PM
gremlin96 gremlin96 is offline
since its just the right side, i would place my bets on a alignment. that would be the side that gets rub when parking on the street with a curb.
Old 02-02-2006, 07:48 PM
777stickman 777stickman is offline
If it's never been aligned before, prepare yourself for the cost of removing the knock out plugs to access the adjustments...........Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-02-2006, 09:38 PM
fire24resque's Avatar
fire24resque fire24resque is offline
Cheapest first try would be to get an alignment and see if it does it again. Also I would just give a quick check over of your front end. Bad pitman arm or idler arm can cause some looseness and causes feathering. I would go with alignment being the cause first but you can never be sure with these WONDERFULLY CRAFTED GMs!!!!!
2001 Silverado 4x4 - 4.8 V8 - Hankook Dynapro ATm RF10s, 265/75/16
K&N FIPK - Flowmaster 50 Series 3.5" Duals
4-Headlight Conversion Kit - Billet Grille
90 Watt Nova Strobe Pack
2.5% Limo Tint -
Check Out Pictures and More Here
http://www.cardomain.com/ride/2131569/1
Old 02-03-2006, 10:48 AM
I am not so sure that "knock out plug" applies to 2000 and newer Chevys. Please correct me if I am wrong.
Old 02-03-2006, 06:44 PM
Just called the local tire shop and if it's never been aligned before they are most likely there...........Steve
57 Chevy 210
Old 02-04-2006, 08:37 AM
Smile Re: Right Front Tire Feathering On Inside
Here is the link that talks about the last 10-15 years worth of Chevy trucks and thier suspensions. Start with the second to last paragraph. It says 2000 and up now have a plastic cover now that requires little effort to remove when accessing the adjustments. The whole article is worth reading also.
http://www.epinions.com/auto-review-...39FB2494-prod1
