Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 02-01-2006, 11:53 PM
rontomed's Avatar
rontomed rontomed is offline
Question Too much transmission fluid.
I've discovered that there is too much automatic transmission fluid in my 1999 Dodge Ram 1500 which has a 318 cubic inch engine. Will I have to drop the pan to drain out the excess fluid or is there a drain tube?
Old 02-02-2006, 01:57 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Too much transmission fluid.
Are you checking the fluid in park or neutral? I believe that transmission doesn't pump in park, so it will give a false high reading. If it is overfull, you could remove a trans cooler line from the radiator and start it. only pump out a little at a time, checking often.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 02-02-2006, 12:57 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Corning is correct in that you have to check a chrylser tranny with it in neutral, because the pump stops working when in park.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 02-03-2006, 01:49 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Neutral.
My Mopars
Old 02-05-2006, 11:31 AM
rontomed's Avatar
Thumbs up Re: Too much transmission fluid.
Thanks corning_d3. Dad taught me years ago to check automatic tranmission fluid in NEUTRAL but I was checking it in the PARK position. I had to add almost a quart to reach a good operating level on the dip stick. Shifting is much better.
Old 02-06-2006, 01:40 PM
Glad to hear it. I can't figure why Chrysler wanted to be different...
Old 02-14-2006, 06:55 PM
rontomed's Avatar
Question Re: Too much transmission fluid.
Shifting from 2nd to 3rd still hangs up in 2nd at times. Someone told me a way to replace the old fluid without having to drop the pan is to disconnect the transmission fluid at the radiaitor, measuring the amount drained and replacing it with fresh fluid. I would repeat the process after driving it for several days to replace more of the old fluid. Only a trickle flows out when I disconnect the line from the radiator. Should I start the engine so that the transmission will pump the fluid out? Will this damage the transmission?
