Old 02-01-2006, 09:29 PM
89civic_sedan 89civic_sedan is offline
Idle Problems
When i crank my car up it will idle at about 2000Rpms then after about 10 minutes it will start to jump from 2000 to 1000 then back and forth and it wont never stop.Then as i shift gears when i push the clutch in it will idle high like 3000rpms and then drop down when i let the clutch back out. Any help would be appriciated.
Old 02-01-2006, 11:27 PM
uiony uiony is offline
Send a message via AIM to uiony
Re: Idle Problems
I had the same problem a few weeks ago. The problem with mine was that I didn't tighten my intake down correctly. I tighten it up and it stopped. That's what I suggest doing.
'90 Honda Civic SI
Old 02-02-2006, 07:29 AM
Re: Idle Problems
Your talking about the intake manifold or air intake.
Old 02-02-2006, 07:58 AM
Re: Idle Problems
Air intake.
'90 Honda Civic SI
Old 02-02-2006, 09:01 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Idle Problems
It could be a vaccum leak. Spray the IM hoses with water and see what you find.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 02-02-2006, 04:18 PM
Re: Idle Problems
I dont know what a IM hose is located.
Old 02-02-2006, 04:26 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: Idle Problems
he is saying the intake manifold(im) vacume lines.
get a spray bottel and spray the lines, they are the small(really skinny) rubber lines...
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 02-02-2006, 04:39 PM
Re: Idle Problems
OK will do. with the car running or not.
Old 02-02-2006, 08:33 PM
Re: Idle Problems
with the car runing, if there is a leak your idle will go down for a sec when you spray water on the line
1990 si hatch
b20b si tranny
50 shot
1994 Dx hatch
stock
Old 02-04-2006, 12:02 AM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Re: Idle Problems
actually one other hting it could be which im pretty sure is your reason is your throttle is sticking open alittle. i had that happened ot me it would idle fine and do the normal thing but once i drove it and pushed the clutch in it stuck open and rev to 3 or 4 grand some times.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
