Old 02-01-2006, 07:48 PM
spivey-1 spivey-1 is offline
stiff ride
Alright, here is the problem i have changed everyt bushing and GREASED everything but the truck is still very stiff. when i hit a bump if fells like the whole front end of the truck is rattling. and when i say rattling it is just the front end. the truck is a 97 s-10 with a 2001 front end. My dime is lowered 3 inchs and i have ground force springs on it with toxic drop shocks. can someone give me some advice please i am about to run the damn thing of in a river and walk away!!.
Old 02-01-2006, 09:23 PM
OverBoardProject OverBoardProject is offline
Banned
Re: stiff ride
Is it rattling, or just feeling like it?
I'm just guessing that you used poly urathane bushings. They are better in every way except ride quality. They are just too solid for a comfortable street ride.
Old 02-01-2006, 10:11 PM
RahX RahX is offline
Re: stiff ride
good call on the bushings. did you get the truck aligned? i know caster can cause a harsher ride to a degree.
Old 02-02-2006, 05:06 PM
Re: stiff ride
It feels like it is rattling, and yes i used polyurethane.
Old 02-02-2006, 05:07 PM
Re: stiff ride
Yes the truck has been aligned.
Old 02-02-2006, 05:11 PM
Banned
Re: stiff ride
It's the bushings then, a very comon thig for people to do. Like I said they are beter in every way, except ride quality.
The 2 things that you might want to try is use a spray lube that won't damage the bushings.
Or replace a few select bushings with OEM rubber bushings.
I don't know which ones effect the ride quality the most.
Old 02-02-2006, 06:19 PM
72 rs's Avatar
72 rs 72 rs is offline
Re: stiff ride
just my 2 cents ,but here it goes. i owned an 87 fullsize pu with the same combo up front; 3in drop springs and toxic shocks, and had the same prob. i fixed mine by going to a 1in drop spring with 2in drop spindles. with the 3in drop springs u lose all the travel your suspension once had .........therefore they ( the manufacture) increses the spring rate so the truck wont bottom out. second prob i had was with the toxic shocks.......mine were bottoming out before the suspension was through its travel.....i fixed this by buying shocks (toxic) that were advertised to be 1in shorter (4in insted of 3in) than what i needed........................all in all it worked for me.......no more harsh ride
87 chevy silvy
91 transam 700r4 and torque convt.
new comp.
hypertech chip
accell ign. cont. modual
dual electric fans
94 lt1 long tube headers
custom exhaust
flowmaster 40 series muff.
3-4 suspension drop
helix tbi spacer
k&n airfilter
custom built cold air intake
Old 02-03-2006, 09:59 AM
herkyhawki herkyhawki is offline
Re: stiff ride
If you want a smooth ride, put the stock suspension back on.
Old 02-05-2006, 07:08 PM
Re: stiff ride
Uh that is not an option, but you are right. maybe i should just bag it and quit bitchin about it
Old 02-05-2006, 07:10 PM
Banned
Re: stiff ride
On the good side, I'l bet that it handles like it's on rails
Old 02-06-2006, 01:21 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: stiff ride
lowering the truck made the ride worse, more stiff, no question about it, and then the added factor of poly bushings made it even worse, 2 choices, one is to put stock suspension back on (you said not an option) or two, bag it, you sound like you want it done anywayse, but that will help ride quality a LOT
Old 02-08-2006, 02:14 PM
Cam1959 Cam1959 is offline
Re: stiff ride
Or lower tire pressure? Use soft kelvar radial tires ?
1983 S10 4WD carbed 2.8L automatic w A/C
Old 02-08-2006, 05:05 PM
Re: stiff ride
no, you dont wanna lower the tire pressure, and that goes doubble if you have low profile tires
