Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-01-2006, 07:08 PM
Revelation Revelation is offline
baffled please help
ok i have a 88 sierra tbi 5.7L
when driving it bogs down from 1st to 2nd gear....not all the time but 90% of the time...also sometimes when i pull in make a turn to my driveway to park the truck it dies sometimes (about 40% of the time) sometimes it feels like a 8 cylinder sometimes it feels like a 4.....when at idle in traffic it acts like it wants to die....now here is the list of things that have been changed over the past 3 months in order
coil
knock sensor
map sensor
fuel filter
exhaust
egr valve
rebuilt transmission
catalytic converter
plugs and wires
now when i look at it when its starts seems the injectors are spraying very well
any input would be greatly appreciated since my funds are almost out trying to get this truck running right
would bring it to a shop to get it fixed BUT all the shops around my area are booked for weeks
Old 02-02-2006, 12:25 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Re: baffled please help
It is probably a warn distributor. Pull of the distributor cap and see if there is side to side movement in the shaft. If so then the bushings are bad, you can either replace the bushings, and possibly the shaft or the entire distributor. These distributors are known for going bad and causing problems like this.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 02-02-2006, 06:48 PM
ok thank you me and my friend gonna do that tommorow during daylight hours hope it does the trick
Old 02-07-2006, 05:01 PM
figure i let you know just so in case any one else ever experiences my problem it worked the truck is running fine now..thank you for your help
