Old 02-01-2006, 04:01 PM
1FASTws6 1FASTws6 is offline
03 cobra question
is it true that the 03 cobra and the 03 GT40 have the same engine. My friend said that the GT40 has the cobra engine but... has a more powerfull supercharger, higher compression ratio, and the body is made outta carbon fiber. Is this true?????????? thanks
Old 02-01-2006, 04:11 PM
01L2Cobra's Avatar
01L2Cobra 01L2Cobra is offline
Re: 03 cobra question
Not its not ture. Nothing is shared from the Ford GT and the 03/04 Cobra. The GT500 only shares the same heads as the Ford GT.
The ///M stands for Motorsports
Old 02-01-2006, 08:19 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
same block to isnt it?
Old 02-01-2006, 11:02 PM
01L2Cobra's Avatar
No not by far!!!!
For starters the GT has an Aluminum block while the GT500 is heavy ass heat retaining pig iron. The GT also has a dry sump where as the GT500 has a wet sump.
Old 02-01-2006, 11:14 PM
TheStang00's Avatar
No not by far!!!!
GT is Aluminum GT500 is pig iron
oh yeah... good call i forgot
but isnt it the same design
Old 02-02-2006, 01:57 AM
Whathits14 Whathits14 is offline
Same displacement. (gt500/gt40=5.4L, 03/04 Cobra=4.6L) Thats about it.
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 02-02-2006, 08:39 AM
01L2Cobra's Avatar
It does share the same displacement and I believe compression. The crankshaft is possibly the same the but remember that some of the first GTs had major issues with theirs you can blame Roush on that one. There is a sensor boss formed in the timing chain cover less than 3/8" from the pulley lip on the GT500 and there is no such sensor boss on the GT. The mounting points for the alternator are also different. On the GT the alternator is located on the top of the engine just like the non SC cobras. The GT500 has its alternator located on the side of the engine just like the 03/04 cobras. The belts are also routed completely differently in the two cars as seen in the pics below.
Ford GT
GT500
Old 02-02-2006, 08:41 PM
Muscletang's Avatar
Muscletang Muscletang is offline
AF Premium User
The 2000 Cobra R and the Ford GT have the same engine. Well, it's not the exact same but they both have a 5.4 DOHC engine.
They may be very close though. The 5.4 N/A is pumping out 380. I think 170 hp could be reached with 14 pounds of boost.
For a long time it gave me nightmares... witnessing an injustice like that... it's a constant reminder of just how unfair this world can be... I can still hear them taunting him.......
silly rabbit, tricks are for kids...
I mean, WHY COULDN'T THEY JUST GIVE HIM SOME CEREAL?
Originally Posted by Lars Ulrich
What?! Record sales are slumping? Must be from all those pirates. Can't be because we started sucking 10 years ago.
Old 02-03-2006, 09:29 AM
01L2Cobra's Avatar
The 2000 Cobra R is yet another totally different 5.4. The R used the 5.4 DOHC Navigators heavy ass heat retaining pig iron block. The heads on the R were totally unique and not even sold by FRPP. The compression ration for the 2000 R was 9.60:1 the GT has a compression ration of 8.4:1.
Old 02-03-2006, 04:38 PM
Muscletang's Avatar
AF Premium User
Different? Yes.
Totally different? I wouldn't go that far.
When you get down to it, it's still the same engine. You can change bores, strokes, intakes, heads, cams, ect but it's still the same design. This is why the new LS-7 is still a Chevy small block that has been around for over 50 years.
Old 02-04-2006, 07:46 AM
01L2Cobra's Avatar
Yes parts can be shared but they can also be shared with the 4.6. The all three 5.4 blocks are different when you get right down to it. The mod motor is not near as success full as the Chevy LS-X engine. The mod motor is way to heavy and not capable of the same kinds of power with out the addition of a power adder. Can Ford produce an engine capable of more than 400hp without the aid of a SC? Well yes a no. Yes they is the CAMMER that produces 425hp but it is so unreliable it will never make in to a production car or even be given a warranty from FRPP.
Old 02-04-2006, 12:24 PM
Joshta's Avatar
Joshta Joshta is offline
What parts can be shared with the 4.6 and 5.4? is it just the heads, or more?
02' Mustang GT - auto, 4.10s, K&N, catback, UDPs, hypertech.
Old 02-04-2006, 04:49 PM
TheStang00's Avatar
well i dont think thats worded properly... im sure they are capable of producing a motor that produces that kind of power while being reliable, if they have is another story. and its not likely going to be a mod motor, but the 5.4 has shown the capability with the cobra R to produce some inpressive power. is the 6.4l v10 a mod motor? that produced well over 400hp... over 600hp, but you know that. and its a smaller engine than the ls7 too that is making 500hp, now if its to heavy is a totally different issue, but it is aluminum is it not.
Old 02-06-2006, 09:08 AM
01L2Cobra's Avatar
The V10 is not a mod motor and there are still issues with it and that is one reason it was not used in the GT and is one reason why the GR-1 will not be built. Even the 2000 R didn't reach the 400hp mark. The mod motor is way outdated under powered and too heavy.
Let’s take a look at a couple of engines.
2001 Ford Cobra
Weight: 614lbs
Displacement: 4.6L
HP: 320
That’s 69.27hp per liter or .52hp per pound
2005 BMW M3
Weight: 326lbs
Displacement: 3.2L
HP: 333
That’s 104.06hp per liter or 1.02hp per pound
Now let's look at a real over achiever
Honda S2000
Weight: not to sure about this one
Displacement: 2.2L
HP: 237
That’s 107.73hp per liter
These are all DOHC engines and as you can see the Ford Mod Motor is defiantly under powered for its size and extremely over weight.
Sources
http://www.fordracingparts.com/parts...tKeyField=6229
http://www.bimmerforums.com/engine_faq/
http://autos.yahoo.com/;_ylc=X3oDMTF...RzbGsDYXV0b3M-
Old 02-06-2006, 09:23 AM
TheStang00's Avatar
hp per liter doesnt mean shit. thats all there is to it. weight does though, along with torque, which is something the s2000 doesnt have. proof that hp per liter doesnt mean shit, ls2, ls7. both are compact and lightweight, and get better gas milage than many lower powered engines. most likely better than that bmw engine. the fact that the 4.6 isnt high on hp/liter just means that ford hasnt dumped truck loads of money into, or like you said the technology is to old. but hp/liter alone doesnt make it bad. i must say though the mod motor does seem unusually large and heavy for being only 4.6l of displacement.
