Old 02-01-2006, 04:56 PM
WReX WReX is offline
Parking Brake not holding
my parking brake/emergency brake is not working very at hold in the truck, any suggestions?
just changed the rear pads and check the brake cable but looks good
thanks in advance
26 PSI anyone?
Old 02-01-2006, 05:03 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
Re: Parking Brake not holding
If by car, you mean Silverado, then there are two things to do:
1. Find the parking brake cable, it is a steel line running along the drivers side frame from the front to the rear axle. There is an adjuster on the cable, tighten the adjusting bolt and see if that helps.
2. If that doesn't work, take off the wheels/calipers/rotors and replace the parking brake shoes. If I remember correctly they will run ~$70 at your GM dealer. Be sure to adjust them properly, just like any other drum brake, and let as much adjustment as is safe out of the adjuster, so that as the shoes wear you can tighten it back up.
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 02-01-2006, 05:04 PM
mike65072 mike65072 is offline
I had the same problem with my '00 silverado. All the adjustment was out of the cable and the parking brake would still go to the floor. The answer was a new cable, or try to shorten the existing cable...so I solved the problem a different way...bought a new truck. Expensive, but effective
Old 02-01-2006, 05:12 PM
thanks for the reponses
i meant truck my bad
26 PSI anyone?
Old 02-01-2006, 08:11 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
It may need an adjustment, or not. My entire system went out and cost damn near 5 big ones. Works like a champ now.
*Under Construction - New sig to debut*
Old 02-01-2006, 11:34 PM
chuck16's Avatar
chuck16 chuck16 is offline
I Did all 4 rotors and all 6 pads just before christmas. Total was just under $400 CAN for all the parts. My Ebrake would hold but not very well. When I took it apart it was fully adjusted and completely worn out. I backed it right out to nothing then put the new E-Brake shoe in. Works stompy now and the regular brakes with new shoes and rotors are really strong too
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
