Old 02-01-2006, 01:22 PM
96blazerlt4x4 96blazerlt4x4 is offline
timing chain?
the v6 4.3 highoutput vin W
it has a timing chain correct?
my husband seems to think it doesnt....he thinks its run off a serpentine belt
Old 02-01-2006, 01:32 PM
herkyhawki herkyhawki is offline
Re: timing chain?
Yes it has a timing chain. It is right behind the cleverly-named "timing cover"
Old 02-01-2006, 01:33 PM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
Re: timing chain?
Yes you are 100% correct. If your husband thinks a serpentine belt does timing, he may as well just give you the tools and let you goto town on the truck! The serpentine belt is for accessories, ie... alternator, air conditioning, water pump, emissions, power steering, and so forth.
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Old 02-01-2006, 02:31 PM
Re: timing chain?
now..when does the timing chAIN need to be replaced??
we have 166k on the truck
Old 02-01-2006, 03:26 PM
the87hyper's Avatar
Re: timing chain?
Replace it. The more the chain stretches the more your timing is off. I'd say every 75K.
1999 BLAZER ZR2
KENWOOD PS-150 AMP
JL AUDIO 10W6
Old 02-01-2006, 03:53 PM
Jeremy Fitch Jeremy Fitch is offline
Send a message via Yahoo to Jeremy Fitch
Re: timing chain?
Most of the time timing chains never need to be replaced! Timing belts are what need replaced. A timing chain is made to last the life of the engine. I would not replace it unless you have a problem.
1996 Blazer LT 4 Door, 4x4, 4.3L Vin W.
Old 02-01-2006, 05:36 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: timing chain?
I agree 100%, and there is no timing adjustment to be done. Just exactly what kind of trouble are you experiencing?
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 02-01-2006, 05:52 PM
the87hyper's Avatar
Re: timing chain?
It is a fact that they do need replaced with mileage. My truck, with 120+K miles was 9 degrees out of timing. After that many miles the stretching of the chain makes the crank and cam not allign the way they are meant. The truck ran fine, however performance was going downhill. Put the new chain in and the lack of power was gone. If i had a older blazer that you can adjust timing on i'd say your right, however on mine you cannot adjust.
1999 BLAZER ZR2
KENWOOD PS-150 AMP
JL AUDIO 10W6
Old 02-02-2006, 09:08 AM
Re: timing chain?
Cam timing and ignition timing are two different subjects. The pre-94 blazers allow adjustments to ignition timing. A stretched timing chain will affect cam timing. The distibutor is driven off the camshaft, but the ignition timing mechanisms will compensate for small variances in cam timing due to chain stretch. If the chain has stretched enough to retard cam timing, (retarding the valve timing), the only way to fix is to replace the chain. I agree that the chains do stretch, and you can gain performance on a high-milage engine by replacing the timing chain/gear set.
Old 02-02-2006, 10:43 PM
Re: timing chain?
we have a 96 blazer 166k miles
it just doesnt seem to have the up N go like it should..it seems the timing is off by quite a bit by the way it idles and runs
we'd like to get the performance back that it should have
now has anyone changed there timingchain by themselves?
the chevy dealer here says dont replace unless it breaks......and it isnt a item they do anymore...
Old 02-03-2006, 03:15 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Re: timing chain?
Chevy dealer doesn't do it ?????? . I guess they only sell them . It's indepth work , not for novice mechanics with a small tool box . and if not installed correctly will destroy the engine at first start attempt. Lots of things have to be removed to get to it . A haynes manual is a neccesity along with some specialty tools . It is almost worthwhile installing a new cam if you are going to do the chain . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
