Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-01-2006, 12:38 AM
bennybenster bennybenster is offline
Send a message via AIM to bennybenster Send a message via Yahoo to bennybenster
help getting integra started
I have a 92 Integra LS and I have spent the past month or so installing a new clutch and flywheel and a few other misc. things along the way. I finally got all the pieces needed put together tonight and was very excited to get it started it take it for a test drive.
Unfortunately, the car won't start. It cranks like it's about to start but just won't turn over. Needless to say, I was very disappointed. I will have to go over everything tomorrow for a third time to make sure everything is put back correctly. I was hoping someone could point me to some direction to make my troubleshooting a bit easier.
Again, the engine cranks but won't turn over. What could I have missed? This is my first time doing this so I might have had forgotten something but I went step by step with the HELMS and I thought I got everything. Please help. Thanks!
BennyBenster
Old 02-01-2006, 02:57 AM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
Re: help getting integra started
wish i can better man, but if u install a clutch and fly wheel, then ur way ahead of me nowadays more into motorcycles, but i thought i drop in the teg forums to see if i can help any. anyways, good luck.
Old 02-01-2006, 09:57 AM
Thanks tran_nsx. My bike's in hibernation for the winter so I'm concentrating on my car for now. But yeah, I'm going to need the luck to get this car going...or some really good help from someone in here. Anyone have any tips for me? Thanks.
BennyBenster
Old 02-01-2006, 10:52 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
first thing is check and see if you have spark and fuel.. since you didnt mess with anything fuel related check the spark... maybe you accidently unhooked a ground or something somewhere
Old 02-01-2006, 11:12 AM
WReX WReX is offline
i'm assuming the cranking speed is normal? if not i would check the battery and also check for spark as ridge runner said
26 PSI anyone?
Old 02-01-2006, 11:15 AM
Yes, the cranking speed sounds normal...although it does slow down after 3-4 seconds. I did do a test on the battery and it tested 12.0v. I'm researching on how to check for spark now. If anyone would like to post up a "how to check spark" here, that would be great.
BennyBenster
Old 02-01-2006, 12:22 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
if its only reading 12 volts it could more than likely be bad. A good battery will test anywhere from 12.6-13. sometimes more.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 02-01-2006, 01:42 PM
TurboGSR96's Avatar
TurboGSR96 TurboGSR96 is offline
Send a message via AIM to TurboGSR96
To check for spark unplug a spark plug wire where it meets your distributor, have someone crank the engine while you hold the plug wire right next to where you unpluged it. You should see the electrical arch jumping from the distributor to the plug and/or hear it clicking.
To check for fuel, if you have a fuel filter mounted in your engine like the picture below, just have someone crank the engine and slowly turn the nut on top of the fuel filter, no fuel comes out you got no pump pressure.
R.I.P 00' ITR #479
1996 GSR: Built Bottom - Built Head - Big Injectors - Big Turbo - Computer Thingy - 500+ whp
*2-6-06* Waiting for the Full-Race Stg 3 with GT35R
.82 a/r Upgrade and Nitrous Express NXL
http://www.cardomain.com/ride/2241056
Old 02-01-2006, 02:34 PM
Thanks for the examples. I will try it tonight.
BennyBenster
Old 02-02-2006, 08:15 PM
Finally got a chance to try the wire/distributor test TurboGSR96 said and I saw sparks. So I'm guessing the distributor is not the problem? What else should I check?
BennyBenster
Old 02-03-2006, 12:08 PM
TurboGSR96's Avatar
did you crack the fuel fitler also? if not look for your fuel injectors...follow the rail that they are mounted to until you find the actual line. Then follow that until you find the filter and crack the nut to see if you got pressure, if it has fuel then im gonna say its the sensor that keeps your car starting without the clutch disengaged. I had my friend take it off my car so I can start it without pushing the clutch (DO NOT GET AUTO START...I DID IT AND RUINED AN INTERCOOLER BECAUSE OF IT). I'm pretty sure you did the work yourself so if I was you I would get under the car if you have not allready and just check everything out. Look under your dash at the clutch pedal and see if all the wires look like they are where they are asposed to be. If it still dont work let me know ill give you an underdash shot if you need help finding the sensor.
R.I.P 00' ITR #479
Old 02-04-2006, 05:56 PM
Cracked the fuel filter and fuel squirted out. Looks like I have fuel. I even tried to jump it and that didn't do much. I have checked and rechecked everything I touched and yes, I did do the work myself.
Just wondering...why would I need to check out under the dash if I didn't even touch anything under there. And where is this sensor you're talking about?
BennyBenster
Old 02-04-2006, 06:34 PM
TurboGSR96's Avatar
As you probably allready know, you cant start your car without pushing in the clutch....there is a sensor that reads this and keeps the car from starting. I dont remember where but somewhere either at the top of you clutch pedal or near/on your tranny there has to be a sensor to tell the engine if the clutch pedal is depressed. I dont know much about your model year so I dont think I can be much more help.
R.I.P 00' ITR #479
Old 02-05-2006, 01:33 AM
^^^ the car doesn't even crank if the clutch pedal isn't down due to that feature but he says the car is cranking
26 PSI anyone?
Old 02-05-2006, 10:25 AM
TurboGSR96's Avatar
lol.....oops, dont know how else to help you then. Better get on the phone to a mechanic.
R.I.P 00' ITR #479
