Old 06-19-2002, 10:01 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
What are the easiest engine swaps?
I am going to do a swap eventually but I am a do it yourself guy and don't like anyone fucking up my stuff but me. So what engine swap is easy to do? I am very good at mechanical stuff but knowing about wiring I don't know too much about that stuff. I heard ZC is very easy to do and is like a straight drop in. I think it is harder than that but what is easy to do?
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 06-19-2002, 10:06 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
The b16 cable type is farily easy if you get the motormount kit.
same goes for the b18 with the motor mount kit
Old 06-19-2002, 10:09 PM
Is B16 easy? I thought it would be hard for some reason. Why has ZC dropped off the face of the earth, all these engine sites no longer have them!
Old 06-19-2002, 10:16 PM
bc4g bc4g is offline
the easiest swap is h22a turbo charrged with NOS its like turning on a light switch ---if you really believe this please sell your car
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 06-19-2002, 10:25 PM
Chad
I'd like to be able to steer my car.
Old 06-20-2002, 08:16 AM
i was just kidding. I had along day at work--a nice 12hr shift
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 06-20-2002, 10:03 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i did a d16y8.it went right in. for some reason people think that swap is really spendy. you can go the cheap route and all you need is the engine and rpm activated switch. i got my engine for $500. so it would have cost the same as a ZC, except for my d16y8 didn't need to be rebuilt (as they suggest you do with a ZC)
ami
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 06-20-2002, 05:12 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
I cant say how easy / not easy it was to do the SOHC ZC swap seeing as it was already in the car, but the owner of the car before me was a poor guy, so it couldnt have been too expensive
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 06-20-2002, 07:19 PM
velocitySiR's Avatar
velocitySiR velocitySiR is offline
Send a message via AIM to velocitySiR
zc=easy as shit.....move one wire to your cam sensor.....
get it at soko i got one for my old rex for $730 shipped....
formerly "riceboi" back at ph
1990 Crx Si ..b16a1 ...i/h/e ...PYR Racing head..ctr pistons .. ...flywheel ...stage 2 clutch ...3.5 drop on Ground Controls ...Koni adj's all around ... ...mugen kit ...sloppy yellow paint job ...apex'i vafc ...gsr brakes ...gsr seats ...autometer a/f gauge ...and more crap that nobody cares about
Old 06-20-2002, 10:44 PM
Do you think DOHC ZC or SOHC VTEC D16 is better? I heard ZC is unreliable.
Old 06-21-2002, 10:39 AM
ya the zc can be very unreiable or very good.... i mean they are a shady motor, personally i'd go y8, but if your really afraid of wires like i am, ZC!
Old 06-21-2002, 03:05 PM
Melt's Avatar
Seems reliable so far, hasnt not started on me yet
AF Bay Area Crew
Old 06-21-2002, 06:25 PM
amy@af's Avatar
go the rpm activated switch route and there is only a couple of wires. go the p28 ecu route, and just get a wiring harness instead of rewiring 50 wires. it's as easy as the ZC. i was stressing before the swap was done...thinking "what did i get myself into". but after it was done i realized it was basically out with the old engine and in with the new.
ami
Old 06-25-2002, 12:23 PM
Lil Cs turbo Zc Lil Cs turbo Zc is offline
Send a message via AIM to Lil Cs turbo Zc
well from whet I heard from being on many web boards for a couple years that the zc swap is very simple. . But it took me 7 weeks to finish..
Old 07-02-2002, 09:37 PM
confucius confucius is offline
go with d16y8, im putting that head on my non vtec block.
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
What is the easiest and cheapest engine swap eghalo '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 05-14-2006 01:27 AM
What is the best engine swap for my 91 maxima?? 91maxbOi Engineering/ Technical 1 09-18-2004 11:32 AM
What are the compatibel engines? ales Engine 2 07-04-2001 11:06 PM
