| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
Loud Hummin Sound
I have a 99 cavalier Z24 with a four speed automatic transmission. The situation is when i drive down the road i have a loud humming sound that changes with vehicle speed. It sounds like it is coming from the passenger side of the car. It sounds exactly like a bad wheel bearing but i replaced that and the sound is still there so i believe it is in the final drive of the transmission. When i take the weight off of the passenger side of the car (by taking a hard turn) the sound goes away, but when i put weight on it it gets louder, just like a wheel bearing. I don't know how to check the transmission fluid either because it has one of those maintenance free transmissions so if someone can help me with that, that would be great.
Re: Loud Hummin Sound
yeah that sounds exactly like a bad wheel bearing, did you fix it yourself or did you take it somewhere?? either way people make mistakes, it may not have been replaced properly
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM, 1981 Fairmont 6cyl 3 speed 1978 Ford Ranchero GT 302 with a few goodies |
I replaced it myself, i replaced the entire hub so i know i didn't put anything back together wrong, unless the new hub was bad but i find that hard to believe, the hub swap is very simple
I have a 2000 Z24 Cavalier with a loud "hummin" sound from the front right. Makes more noise when I turn right. (Left or right bearing ??)
Could someone walk me through changing the hub assembly ? I'd do it myself, as I'm pretty handy with that stuff...just need a walk though... Thanks, ago |
ago check the brakes casue they have those things pn them hat tell u if brake is going bad
oh ya on my 2000 sunfire there is a plug on right side of trans ,seen the mech pop it out ,he said if it drips she`s good to go . hope this helps
Life Is A Highway ,Enjoy The Ride
I don't think it's the brake wear pins, as those sound quite different. I'm thinking that it's now from the forward left side. Do I have to get hub assemblies that include the ABS sensor ?
Can I change the wheel bearing/hubs myself ? Or does it require air tools, etc.. Thanks, ago |
