Old 01-31-2006, 09:22 PM
bigsteve94 bigsteve94 is offline
Bright Lights don't work
I have a 99 cavalier Z24 and my problem is that the bright lights do not work. The low beams and the daytime running lights work fine. The situation is that when i am driving and i click the headlight switch to turn the brights on, the low beams go off and the daytime running lights turn back on but the high beam light on the dash comes on. Anybody have any ideas?
Old 01-31-2006, 09:33 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Bright Lights don't work
daytime running lights relay??? (inside your fusebox)
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 02-01-2006, 11:12 AM
i pulled the daytime running light relay out of the fusebox and tested it with a seperate 12v source and it works. What's the next step?
Old 02-01-2006, 01:29 PM
oneroundko's Avatar
oneroundko oneroundko is offline
New bulbs?
There are 4 different bulbs inside your headlights. Pop your hood and notice the two bolts right above the headlights. Take them off then check the bulbs, they might be burnt
oneroundko's Avatar
BTW, where is the relay for cavalier headlghts anyway?
Old 02-01-2006, 04:47 PM
its not your bulbs cuz you said your daytime running lights still work, they use the same exact bulbs as your high beams,
and ONEROUNDKO, you didnt read this thread very well did you???
Old 02-01-2006, 05:50 PM
oneroundko's Avatar
Oh, yeah, got it.
Cavys are an electrical nightmare it seems.
Old 02-08-2006, 06:04 PM
the relay is located in the fusebox inside the car
