A/c Issue
OLDS 1991-Regency ELITE- 32.000 miles only, from show room to me.
AC gas pressure OK, no leaks, fuses and relay OK. Whem you press ON the compressor donīt engage. If you by pass the 12 volts works OK. Eletronic dashboard at AC and other gauches. Inspected the AC eletronic painel (took out) working fine. Should be same wire that conect to the īregulator module? Any sugestion? I really will apreciate it. Malachias (Brasil)
Re: A/c Issue
You need a factory service manual to diagnose stuff like this. Fortunately you can get them on CD these days and they are not that expensive. Try eBay. . .
Good luck! |
Re: A/c Issue
Malachias |
Re: A/c Issue
No problem!
Brasil?? You will have some problems finding parts, no? The factory service CD is something every car owner must have to work on modern cars with computers and advanced electronics.And, yes, it is quite cold here! It is snowing in the mountains but not in the lower areas, thank goodness.
