Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-31-2006, 06:27 PM
93talonricer 93talonricer is offline
93 talon engine problems
ok havin a problem with the engine. when i bought the car he said that one of the vaules were bad so i took the head of and fixed the vaule and put it all back together and put new spark plugs and wires on, set the timeing right and everything, go to turn it over and it cranked a few times the made like a firing noise but didn't start so i took out the sparkplugs and seen that one of them was bent at the tip and it was the same cilinder that had the bad vaule what could be causeing the piston to hit the spark plug?
ps it has a 1.8 block and a 2.0 head. if that should make a difference.
thanks,
Derek.
Old 01-31-2006, 06:40 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: 93 talon engine problems
I think you may have found your own problem...
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-31-2006, 07:15 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
is it possible to put a 2.0 head ona 1.8?
Old 02-01-2006, 04:24 PM
its only in one ciliendar and from what i checked on it doesn't make a difference from what i was told. but you think i should jus get another 2.0 block for the head?
Old 02-01-2006, 11:52 PM
SLoe's Avatar
SLoe SLoe is offline
WTF, you put a head on from a completely different engine and didn't measure clearances? Shame on you! I wouldn't have admitted that to anyone. WHY????
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 02-02-2006, 02:13 AM
the reason why i put a different head on it is b/c thats how i bought the car. the 1.8 and 2.0 don't make a difference on the clearence. if it was a big deal then it would have hit all the spark plugs not jus one. and i'm not admitting anything i didn't put the engine together like that the person i bought it from did. an i already thought about getting a different block. plus whoever had the car before me messed up the wiriing it has everything for the 2.0 but the 1.8 block. so i'm stuck tryin to get this bitch runnin.
Old 02-02-2006, 06:00 AM
SLoe's Avatar
OK, the piston slapping the plug could be caused by worn rod bearings, or wrist pin. I can't think of anything else that would cause just one cylinder not to have clearance. Fly-cut the piston, or get some indexing washers for the plug. You are positive the timing is right? Sounds like you got a messed up situation. Good Luck
Old 02-02-2006, 12:37 PM
I'm almost 99% positive the timeing is right i too the shield off and reset the bottom two and then put the camshaft in the right alignment. but i'll try the washer thing. thanx.
