Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-31-2006, 02:06 PM
Cardiffkidkid Cardiffkidkid is offline
Smile misfire
Hi, I have a low end misfire. whenever I give it the gas it misses for the first few seconds. Been told it's probably a bad plug wire. I had already changed the plugs, made a difference for a couple of weeks but it came back. Is there a way to check the plug wires? maybe with a meter. could it be one of the coils? the car is a 96 mustang GT 4.6 v8. Thanks Kent
Old 02-20-2006, 01:42 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: misfire
Do you know how many miles you have on those wires? A fast and easy way to check for a leak in the wires is to check them in a dark area with the engine running, you may find a spark escaping from the boot area of the wire. The coil could also be a possibility, but I'd change the wires first. If you still have the problem after changing the wires, you can have your coils checked at autozone
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 02-20-2006, 11:35 AM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
Re: misfire
Take your volt meter and set it to the ohm setting, disconnect the plug wire, put the + on one end and the - on the other, check your reading and check the rest. If one is way off from the others you have a bad wire.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
