Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-31-2006, 12:14 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Window Crank Removal... Stumped.
Hi guys.... I was wondering how to take off the window cranks on a 97 Plymouth Neon. I know GM cars have a tool to use to take of the little metal clip that holds em on, but these are different. Any help would really be appreciated. Thanks in advance!
Old 01-31-2006, 05:07 PM
Fractured1 Fractured1 is offline
Re: Window Crank Removal... Stumped.
there is a clip behind the crank sort of like a horseshoe...I bent a tight "J" on a thin long screwdriver to snag it...put it back on the crank before installation and just give it a tap with your hand to install (if you have a dental mirror it will help you in the clips orientaion)
Old 03-08-2006, 11:48 AM
miguelito miguelito is offline
Use a wire hanger that is bent into a v-shape to hook onto the clip and pull it off. after u get the clip out Dont Pull Off The Panel disconnect the door handle rod inside the panel without moving the panel too much (u may damage it) and disconnect the plastic clip by pushing it in the direction opposite of the rod . if u did it correctly, u should be able to lift the rod smoothly out of the clip .the clip should remain in the panel. The speaker size is 6.5 Good luck!!!!
Old 03-08-2006, 11:58 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
It's been two months since he posted, so if he hasn't figured it out by now he's in bad shape!
