Old 01-31-2006, 11:36 AM
lonelyjoe lonelyjoe is offline
jack
i have a 1995 jeep cherokee, i have no booklet. i need to know where to place a floor jack for a front tire that i have to change. any help would be appreciated. thank you.
Old 01-31-2006, 03:31 PM
Jeepme Jeepme is offline
Re: jack
Place the jack under the axle on the side that you are lifting. I put mine next to the lower suspension arm bracket.
Old 02-04-2006, 11:42 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: jack
If you have a floor jack and stands you can jack from the differential in the middle. If you have 4 stands, you can do both ends and rotate the tires while you are at it. I have 2 floor jacks and I lift one side from the frame area where it is reinforced for the suspension components. That way you can rotate one side at a time.
