Old 01-31-2006, 10:35 AM
parked parked is offline
Loses power after warmup
I have a '89 Camaro RS , 8 cyl, 305. Car starts up fine, and runs fine,for about 15 minutes. Then while in drive or reverse the engine sputters and I have to hold the pedal all the way down to slowly pick up any speed. When I put the vehicle in Park, it idles and rev's fine. Whats causing this ?
Parked
Old 01-31-2006, 10:44 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Loses power after warmup
Have the ignition control module tested, multiple times.
Old 01-31-2006, 05:21 PM
malletslinger's Avatar
malletslinger malletslinger is offline
But you should also check your cap, rotor, plugs, vacuum hoses, and timing. All of which should only take about an hour(give or take).
Old 02-02-2006, 11:28 PM
Thanks for the info, this seems to be where the problem originates from, I'll change the fuel filter to.
Parked
Old 02-02-2006, 11:54 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
is it running hot also? if so change thermostat, and flush raditor.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-14-2006, 12:33 AM
AFI 05 AFI 05 is offline
Send a message via AIM to AFI 05
coolant temp sensor, usually cars run like shit shit if this is bad when car is warmed up.
1990 IROC-Z 5.7 TPI (1 out of 4,213 IROC's made in 1990) Only mod is magnaflow 3" cat back and K&N filters... im broke.
Old 02-14-2006, 02:12 AM
Did you check the trouble codes? Mabe the computer wants to help
Old 02-22-2006, 03:16 AM
Talking Re: Loses power after warmup
Found the problem, throttle body gasket got sucked into the intake. Car runs great, gotta start watching out for speedo tickets again.
Parked ( no longer)
