Old 01-31-2006, 09:14 AM
Renegade2k Renegade2k is offline
Send a message via AIM to Renegade2k Send a message via MSN to Renegade2k Send a message via Yahoo to Renegade2k
2000 intrigue A/C clutch bearing removal
I have a 2000 olds intrigue with the 3.5 and my A/C clutch bearing is making noise. All the manuals I have a vailable say that the nut holding the plate on is a 13mm. The actual nut is round with one notch cut into it. I can't find the proper tool to fix this. HELP.
Old 07-30-2006, 10:17 PM
jnasiatka978 jnasiatka978 is offline
Re: 2000 intrigue A/C clutch bearing removal
Hey did you ever find the tool for the job, I have the same problem. I need to find that socket or whatever tool to remove that bolt.
Old 07-30-2006, 11:00 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Try autozones loan-a-tool. Remeber not to touch the ceramic seal..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 07-31-2006, 08:14 AM
after looking closer, it turns out that the "Nut" I was talking about was actually part of the shaft, making it a stud. It has threads at the end, but has a smooth part before this part. the little notch is a keyway that a shearkey is inserted in. I wasn't able to get it out.
Dealership typically just replaces the compressor, and didn't know what I was talking about.
I eventually had to bite the bulelt and buy a reman compressor. Sucks because they actually make a servicable compressor. Too bad I don't have one.
Old 07-31-2006, 12:37 PM
I never re-bearing an A/C compressor because usually the "nose" where the bearing rides is cracked/broke off/soon-to-be.. I hit a salvage yard n got one for $80 w/ 6 mo. warranty for my monte...couldn't pass that up.
Old 08-03-2006, 01:07 AM
JamesAZ JamesAZ is offline
I've got the same problem with the A/C, anyone have a good online source for the compressor?
Old 08-03-2006, 01:50 AM
Are you wanting to rebuild the compressor? Most manuals you buy leave out most of the A/C system, because your supposed to be certified to mess with it. Can't have all these people draining their freon into the atmosphere...
