Old 01-31-2006, 08:46 AM
crxsir90 crxsir90 is offline
carbon fiber hood...
yo i got a vis carbon fiber hood with predrilled holes for the windshield washer nozzles. does anyone know if the stock nozzles fit these holes. has anyone here put washer nozzles on one of these hoods with pre drilled holes that Vis provides. i got some from a 1994 civic and they didnt fit(little too big), so im just wondering if the stock ones will. peace
Old 01-31-2006, 10:31 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: carbon fiber hood...
What are you saying...I have A Vis hood on my crx and I use the nozles off my old hood and put them on the new vis hood fine...so you aksing will they work yes but whats 1994 nozles have to do with 88-91...not everything is interchangable try to stick with the year of the car
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 02-01-2006, 07:40 PM
yea i tried to find some for my year but the auto parts store wanted 12 bucks apiece plus they had to order them with a waiting period, so i tried the 94's cuz they were free. i figured the stock ones would fit, but the stock hood didnt have any on it, and i didnt want to spend money on ordered parts that may not fit..but i guess they do....thanks man...peace
Old 02-01-2006, 11:29 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Had the same exact problem... With both of my CF hoods, and the latest was a ViS... What you have to do is widen the holes, but you must be careful!! I used tape on the top because the clear coat will chip! I did it to my first hood! Once u have it taped off, go underneath the hood use a dremel with the router bit and carefully widen the holes until they fit... Keep test fitting them cuz once u take too much off, you cant add it back...
Old 02-10-2006, 01:14 PM
Exempt......did you have to drill even while using the stock sprayers?.....would it have been possible to chip the sprayer smaller?...i really dont want to cut the hood, ive seen some bad spider cracks because of that, but then again no tape was used like you had done.
Old 02-10-2006, 09:11 PM
Yes, my nozzles were the same carried over from my original stock hood... I dont see why u couldnt trim the nozzles, I didnt think of that honestly... Might have been a safer way to go... The nozzles have like a small notch outward on them that can probably be sanded or grinded off... Thats actually is what stops u from inserting them properly, atleast thats what was stopping mind from going in...
Old 02-13-2006, 09:44 PM
alright, im gonna try sanding the nozzles first......then take it to a shop to widen the holes, or just dremel it with tape like you did.....thanks for the info
