Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-31-2006, 06:44 AM
km23honda's Avatar
km23honda km23honda is offline
Send a message via AIM to km23honda Send a message via MSN to km23honda Send a message via Yahoo to km23honda
Not as fast as i thought
About 3 months ago i bought a 97 GSX ,clutch was gone so i replaced that and have about 400miles on that clutch its strong ACT2100 good grip. Anyways me and my friend were driving home in my GSX i figured i will floor it. So i go trough the gears a couple times and do a down shift, 60mph and shift to 3th. My friend says it doesn't feel like its boosting as much as what is says on the gauge (12psi)
I think he is right even though i never rode in a GSX but have driving in trubo cars that pull way more then mine does.
What could this be??? Mods are Boost controller, 3.5 cat-back exhaust thats that. Sorry if this is a repost. Any help would be Great. Thanks.
1992 Honda Prelude SI
Old 01-31-2006, 09:32 AM
Bodack Bodack is offline
Send a message via AIM to Bodack
Re: Not as fast as i thought
Boost leak maybe. When you punch it you should definitely feel 12psi.
1993 Honda CBR900RR
1990 Talon TSi AWD - Sold
1990 Laser RS turbo - Sold
1993 Eclipse GS - Sold
Old 01-31-2006, 09:41 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I definately agree, that sounds like a boost leak.
Same thing happened to me on my GS-T.
You can build a boost leak tester, I know there is a link to it in the faqs.
But make sure your intake, bov, and intercooler piping is all connected nice and firm.
Also make sure you MBC is hooked up correctly.
1991 GSX 2.3 Stroker
Old 01-31-2006, 10:53 AM
And since I was JUST reading it because I have a VERY tiny leak somewhere, here's the link. http://www.vfaq.com/mods/ICtester.html
1993 Honda CBR900RR
Old 01-31-2006, 11:07 AM
Gsx_hooptie Gsx_hooptie is offline
Like the guys before me stated...
I'd do a common sense test first. Look under the hood and see if anything looks amiss. Follow the air pathway, squeeze the IC hoses, check couplers, etc. Then do a boost leak test next.
The stock turbo on 2gs is small. It may have been running out of breath at the RPM you were shifting.
Are those the only symptoms?
Is the boost dropping at any point?
Why is it only set to 12?
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 01-31-2006, 01:27 PM
km23honda's Avatar
I will check that out today i that would be the easy part of finding something worng.
I figure the trubo is small but they way i feel the it kick is not as much as 12psi. Also when im flooring it and i hear the turbo wineding (its loud) so i figure its working.
no, i don't think so.
The werid thing is that the boost gauge stays at 12psi the whole time, and is that normall?
its set at 12 becuase i have not changed it at all its has a MBC and i have not messed with it im figureing it still. Plus i dont' want to i think 12 if enough. When you say "only set to 12" is that bad???
Thanks for the help more help would be nice, hope its just a hose.
Old 01-31-2006, 02:04 PM
defiancy's Avatar
Well 12 is just a little low for a car that has a MBC most people run about 16-17psi on an MBC because that is about the max efficiency of the t-25.
I mean even at 12psi you should still feel the thing pull pretty hard.
Also what is your vac at idle?
Old 01-31-2006, 02:15 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Stock boost on a 2g turbo is ~14 psi, so if you're only running 12, it would feel pretty slow. When I put my MBC in, I went up to the track to test it out. I "set" it at 15 psi the day before, but I guess I didn't tighten the lock nut all the way, and I only ran about 10 psi! Talk about slow lol.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 01-31-2006, 04:03 PM
km23honda's Avatar
When its at 12psi and im flooring it, it feels like it takes forever to get to 7000rpms, the gear around is second and thrid is when i really notice that it takes forever to get to red line. (shifting point) My Honda N/T didn't even feel that slow, I checked my hoses i see one that might need tighting but i don't think its a big deal its a small hose around the BOV. could that be the boost leck?
Running 15psi i would think thats a lot?? Is it safe sounds like it is from what you guys are saying. At idle (1000ish) i think my VAC is 20 is that too much.
Old 01-31-2006, 06:06 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I think you should just give up and give it to me .
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-31-2006, 08:09 PM
Nayr747's Avatar
Nayr747 Nayr747 is offline
15 psi is not a lot. I know it seems like it is because Hondas with turbos always run very low boost. I have no mbc on my car and it's at 15-16 psi naturally. The boost leak tester should cost you around $50 to make, but it's one of the most necessary things for your DSM. I had a leak between the gasket of my bov that I could only find with the tester.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 01-31-2006, 08:36 PM
b00stedspYder b00stedspYder is offline
Talking Re: Not as fast as i thought
yes def. boost leak...ive had this problem many times...ive still got one i jus cannot find...but like everyone said, you will need that leak tester...i made mine for like 20 bucks and it works great. check every hose and every clamp, its possible for them to be broken and rusted even. my turbo sounds extremly loud at first, but come to find out it was all the leaks...now its a quiet sound until my greddy type s comes in! but yea def get that tester and try that
