Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-31-2006, 01:33 AM
rontomed's Avatar
rontomed rontomed is offline
Exclamation 1999 Auto Transmission Shift Problems
My 1999 Dodge Ram 1500 automatic transmission has difficulty shifting from 2nd to 3rd at times. This usually happens if I am easy on the accelerator. A harder acceleration shifts fine. I bought this three years ago when it had 90,000 mines on it and it now has 120,000 miles.
Old 01-31-2006, 07:31 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: 1999 Auto Transmission Shift Problems
Have you had the tranny fluid and filter serviced and the correct fluid installed? That's where I would start.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 01-31-2006, 08:50 PM
troy1 troy1 is offline
AF -Advisor
Sounds like the 3 clutch inner seal. They get old and shrink up into into the grove and dont seal properly. Very common problem with the Dodge's
Old 02-01-2006, 05:40 PM
wafrederick wafrederick is offline
Banned
It might be electrical,the solenoids.You can use dextron,but pour in Lubegard(black bottle,one bottle only) in too.You can find lubegard at any parts stores.The lubegard does work.Also check the bottom transmission line towards the radatior,the rubber hose part.There is a plastic checkball in that line and REMOVE that checkball.You will burn the transmission up that way if you don't,the plastic checkball melts and plugs that line up.There is a tsb on that,some dumb engineer at Chrysler thought of that and it was a really bad idea.
Old 02-01-2006, 06:08 PM
neon_rt's Avatar
neon_rt neon_rt is offline
I totally dis-agree with the Dextron and Lubegard recommendation. The Lubegard addresses the friction modification needed but still does not account for the fact the some brands of Dextron has incompatible detergents that will destroy the clutch material and ruin the transmission. Use only the MOPAR ATF+ series (3 or 4) that is called for. You may get lucky and the additive work, then again you may not and you will need a new trans.
Old 02-02-2006, 07:08 AM
Banned
The Lubegard changes the dextron into the mopar fluid and it says on the box instead of paying $5.00 a quart for the mopar fluid.Chrysler does approve Lubegard,it says on the box..That plastic checkball in that transmission line that I mentioned,Chrysler origanally put that in for preventing antifreeze going into the transmission.It was a huge bad Idea,it melts and plugs it right up
Old 02-02-2006, 12:23 PM
neon_rt's Avatar
OK Mr LubeGard,
I have viewed a picure of the box have concluded, you've been duped.
I did not see an endorsement from MOPAR or any other manufacturer for this product. The language on the box says that the product will convert DEXTRON to a Highly Friction Modified Fluid such as.... and it gives a list of HFM Fluids. It doesn't say it converts the fluid for use in these apps, it says that the fluid is now a HFM fluid. That still does not make it compatible with Mopar transmissions, since it is the nature of the addatives that give these transmissions problems. I did not see any hint of Manufacturer approval on the box or on their website or anywhere, just clever marketing language. I think this is the stuff that @@mc0 puts in MOPAR transmissions when you don't pay for the 3 year extended warranty. The transmission lasts about a year to year and a half and dies b/c the clutches are flaking apart and clogging everything up.
Part 2:
I found this later after making my rant above. My jab at @@mc0 was due to a personal experience, aparently someone else has had the same experience.
http://www.noria.com/message_boards/...essagenumber=1
Old 02-02-2006, 12:57 PM
AF -Advisor
A late 2-3 shift under accleration is a bad seal on the direct drum (3rd drum) The minute you let off the gas it shifts right?
Old 02-02-2006, 06:29 PM
Banned
Most of the automakers approve Lubegard.You did not look good on the top of the box.I have used Lubegard in Mopar transmissions WITHOUT any problems and the transmissions worked.
Old 02-04-2006, 08:21 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Wow.
My Mopars
Old 02-05-2006, 11:37 AM
rontomed's Avatar
Thumbs up Re: 1999 Auto Transmission Shift Problems
I was checking the trans fluid in Park. Checking it in NEUTRAL indecated that it was almost a quart low. Shifting much better now.
