Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-30-2006, 10:17 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Problem relieving fuel pressure
Ok, so to remove Mikes engine we need to relieve the fuel pressure. The Haynes manual says to unplug the fuel pump and let it run until its out. Well, his car doesnt start. So what now, do we just disconnect the fuel lines and hope to god we dont blow something up? Thanks guys.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-30-2006, 10:19 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: Problem relieving fuel pressure
open the gas cap to releave tank pressure then losen the bolt on the top of the fuel filter untill gas starts coming out(make sure to have a rag right there) and that will bleed off the pressure without anything spraying
EDIT: any word on the injectors?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 01-30-2006, 10:20 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
There's not much fuel in there and it smells pretty good. Just try to soak most of it up with a paper towel.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-30-2006, 10:28 PM
Thor06's Avatar
Jizzed In My Pants
Sweet, thanks guys.
pr_ricer, PM sent.
