Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-30-2006, 08:08 PM
northriverflames northriverflames is offline
Send a message via MSN to northriverflames
Air Suspension
Hey
I dont know a whole lot about suspension, upgrades, and the specifications for our cars. But i was wondering if its possible to put an air ride suspension into an AWD. I would like to be able to adjust my suspension in the car from stiff to softer. But i would also like to lower the car an inch or so. Yes i know i can put new shocks and springs in it that will lower the car and stiffen it. But are there air shocks out there that you can control and lower the cars ride hight and stiffness? Any info would be great! Thanks
Tony
2000 Chevy Silverado 1500 4x4 Extended Cab.
1996 Pontiac Sunfire GT 5 Spd.
1992 Plymouth Laser RST AWD 5 Spd.
Old 01-30-2006, 08:36 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Air Suspension
I would not recommend adjustable suspension, unless you are a die hard track guy or you have a crazy modified show car. I've heard air suspension rides like hell. You could get coil overs, but I wouldnt suggest it. Everytime you adjust it, it throws your alignment off so you either get fucked on alignment costs or your tires will prematurely/unevenly wear. How far would you like to drop? Eibach Sportlines are ~2" and the Pro Kit is like ~1.25 IIRC, I would go with one of those paired up with KYB AGX's, Koni Yellows, or Tokico Illuminas.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-31-2006, 09:55 AM
Gsx_hooptie Gsx_hooptie is offline
Re: Air Suspension
Read these three paragraphs or do Cliff's Notes at bottom.
If you care...
The most popular in-car adjustable suspension on DSMs is Tein's EDFC. It reduces shock travel, which is very bad. It also costs a grand. It's a rice mod. Where's my flame suit?
Koni Yellows are the high performance and comfy way to lower your car. A lower ride doesn't necessarily mean a stiffer ride. It depends on whether you're fucking with the sprung or unsprung weight of the car, and only Koni allows the adjustments necessary for DSMs, until you talk about higher dollar coilovers. Konis are six hundred dollars. The good news is that they won't need to be adjusted, really.
Or you can get new code AGXs or Illuminas and put them on the "soft" setting for a comfy ride on a lowered car. I think they're both on-car adjustable, but I don't remember. I've posted about it before if you search. These run 200-300 dollars. Not high performance.
Cliff's Notes:
Buy Tein EDFC if you don't care about performance. Expensive.
Buy Konis for a soft ride that is also a performance ride. Moderate.
Buy new code AGX's or Illuminas for a soft ride that isn't a performance ride. You can still be lowered. Cheap. *
*Or your AGX/Illuminas can be performance oriented and sacrifice their ride. With their limited adjustability it's one or the other.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 02-01-2006, 03:50 AM
Re: Air Suspension
Thanks for the info!
Old 02-01-2006, 05:10 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Air Suspension
air on a GSX would be really tough on the CV's, unless you only slammed it while parked.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 02-02-2006, 08:15 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Air Suspension
i thought of putting air-ride on my 95 awd talon but there aren't any manufacturers out there that sell a kit for the awd, just the fwd. i wanted to have it slammed while parked but then just a normal lowered driveable height while moving. i looked around for months but couldn't find really anything reputable, you can try on your own if you like. i e-mailed Air Ride Technologies several times but they never e-mailed me back. let us know if you find anything.
95 Talon TSI AWD
97 Eclipse GST
Old 02-02-2006, 05:39 PM
Re: Air Suspension
Thanks, Yeah thats what i was a slammed car while parked, and a low car while driving, with a bit better handleing than stock suspension. Ill keep looking into it, but thanks for the info everyone!
