Old 01-30-2006, 07:56 PM
KJTooltime KJTooltime is offline
Failed smog
Hi All,
I have a 1987 IROCZ 5.0L with tune port injection. It failed the NOx test. Prior to the smog test, I replaced the Cat. Everything passed with flying colors except for the NOx test at 25MPH load. It was allowed 700 but had 1904. The funny thing is that it passed easily at the 15MPH load with 201 measured. I have checked the vacuum to the EGR while running down the road and it is fine (10 -15 in. HG. under load). I did all the testing for the EGR valve and EGR solenoid and they all pass. Is there some other component that will cause high NOx? Any help will be greatly appreciated.
Old 01-30-2006, 08:00 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: Failed smog
02 sensors?
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 01-30-2006, 08:27 PM
Re: Failed smog
I think there is only one (driver's side). I have not replaced it. But I am not getting any codes showing a lean or rich mixture from the computer. Would the O2 show a high NOx at 25 MPH but a low NOx at 15 MPH?
Old 01-30-2006, 10:15 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: Failed smog
check your air filters and try and clean out your throttle body a little. Sometimes if your motor isnt getting enough air it can do that.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 01-30-2006, 10:17 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Failed smog
ya, do that and run injector cleaner in it and try it one more time, i here it can reduce numbers big time.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 01-30-2006, 11:02 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
Re: Failed smog
where do you live that you are having emissions test run on a '87? here in arkansas i can already get an antique tag for my car haha
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 01-30-2006, 11:14 PM
Re: Failed smog
I replaced the air filters and cleaned the throttle body. I'm going to try the injector cleaner and run 91 octane (help keep things stay a little cooler in the combustion chamber). The only thing that throws me is why does the NOx have a high reading at 25 MPH and a low reading at 15 MPH.
drvngstorm05 - good old California. Where they keep making the smogs harder and harder. I thinks it time to move to Arkansas where life is good!
Old 01-30-2006, 11:18 PM
Re: Failed smog
life is good and cold here...
high levels of NOx i believe is evidence of running lean correct?
Old 01-30-2006, 11:38 PM
Re: Failed smog
Yes lean is one of the factors. I know the EGR is used to cool the combustion chamber (usually is the main cause of high NOx when it is not working). Maybe the O2 sensor works fine under the the 15 MPH load test but can't keep up during the 25 MPH load test and thus gives a real lean mixture.
Old 01-30-2006, 11:48 PM
Re: Failed smog
egr actually increases intake temp... john told me a while ago that some cars actually got better emissions w/out the egr...
Old 01-30-2006, 11:51 PM
Re: Failed smog
cleaning the injectors will prolly alleviate the problem, don't know if it will solve it but it should definately help... if all else fails put bigger injectors on it w/out tuning it, then it will definately run rich lol
Old 01-31-2006, 09:35 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Failed smog
A fuel problem (or spark for that matter) will result in a HC out of limit.
NOx is stricly the EGR and AIR systems. The EGR on these I believe is a negative backpressure type so vacuum testing gets tricky.
Did you check the vacuum hoses out? 25 mph is when it s.b regulating the most and it's not.
Old 01-31-2006, 09:56 AM
Re: Failed smog
I followed the book on all the testing of the EGR and EGR solenoid. I checked all hoses for leaks and everything is good. I could see the diaphram of the EGR moving and the EGR drops vacuum when the car is started (as stated). I have not tested the AIR system (it has a smog pump). Will this contribute a lot to the NOx if it is not working properly?
Old 02-02-2006, 12:07 AM
Re: Failed smog
i wouldn't think so... simply because NOx involves a lean air fuel mixture... air pump adds air to the exhaust to completely burn up any excess fuel... if the air pump wasn't working then you would have rich exhaust...
Old 02-02-2006, 01:05 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Failed smog
NOx is formed by high combustion temperatures. A lean A/F ratio (in the cylinder, not the exhaust) can cause this. A hot running engine can also cause this, as can over-advanced static ignition timing. Carbon buildup in the cylinders can cause this, too. The exhaust reintroduced to combustion via the EGR system is designed to cut down on this pollutant by reducing peak combustion chamber temperatures. Air injected into the cat is also supposed to lower the emissions by catalysis. Two things I would check are:
#1, the EGR system as everyone else has touched on. Take the valve off and check to make sure the pintle moves freely. Sometimes, carbon can build up in the area around the pintle to the point the thing won't move. Lightly tapping with a hammer should free it up. Also, you can do a quick and dirty test on the diaphragm by depressing the pintle as far as you can and sticking a finger over the vacuum line. If the diaphragm (and pintle) immediately return to the no vacuum position, and you don't feel vacuum on your finger, then the valve is suspect. Also, check the EGR solenoid and the vacuum lines to ensure they all properly work.
#2, the smog pump (AIR system). Make sure the pump works! Make sure the electric valves operate properly and that all vacuum lines are in working order. Double check the check valve on the line dropping down to the cat to ensure it isn't blocked by carbon buildup. If no fresh air from the AIR system makes it down to the cat, the cat can't do its job with the NOx.
You should not have a mixture problem if the EGO sensor properly works and there's no service engine soon light (trouble code) relating to the EGO/mixture. Remember that a rich mixture will lead to early demise of both the EGO sensor and the catalytic converter - so if you have had a problem in the past with a rich mixture, you might need to change both of these.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
