Old 01-30-2006, 07:04 PM
perrenial151 perrenial151 is offline
rear shocks
what's this hardest stiffest shock absorbers I could buy for the rear of a 93 dodge caravan so the back doesn't sag under heavy loads?
And where is the diagnostic link connector to check codes with a scan tool?
Old 01-30-2006, 07:26 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
Re: rear shocks
if you want something to hold the car up, you buy springs, not shocks
Old 02-02-2006, 04:36 PM
Mrbizness1 Mrbizness1 is offline
Re: rear shocks
The link connector is located under the dash near the sterring column
You can install air shocks to stiffin your suspension.
http://www.shockwarehouse.com/cgi-bi...s/mon_air.html
Old 02-02-2006, 05:23 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: rear shocks
Shocks (also known as dampeners, in some circles) dampen the movement of the spring, they do not support any weight. You can get air shocks, at that point they are not as much a shock as they are a air spring. They still call them shocks b/c the air in the shocks is chaneled through small holes in order to slow movement of the suspension. For the most part they don't perform their shock duty very well and the ride quality suffers. In order to have any shock value you need to keep 25 to 40psi of pressure in them. Unfortunately the pressure also "jacks up" the rear end and causes problems when there is no load to hold it down.
Old 02-07-2006, 07:39 AM
drummertom drummertom is offline
Re: rear shocks
Check out my post on sagging rear end on my 95 T&C. This worked for me!
Old 02-07-2006, 09:42 AM
vipergg vipergg is offline
Re: rear shocks
On new vehicles they actually do have shocks that boost up the rear end under heavy loads . They are called nivomats and they cost like $400 a piece . I doubt you can retrofit them though , think they are specially made to fit particular vehicles . I have them on our 2004 T&C , they are part of the tow package . Not looking forward to replacing those down the road . They look like they belong on the full size pickup , they are HUGE!!! These are not air shocks either , they are special hydraulic shocks that basically pump themselves up under load after driving down the road for say a mile or 2 .
